spark plugs
Bought the electronic ignition for my 199B, last year 350 and noticed the it needs a spark plug that has the threads on top instead of the modern style plug for the boot to fit, I am using an NGK BPR4ES. Is there a plug that will work with this boot or do I need to convert the boot?
1 hour ago, b40rt said:
Does to top of the plug not screw off ?
No, few plugs today do. Need to find one that does or change the boot
You have a plug with a solid terminal. You can get the same plug either threaded or with a removable nut, no need to change the heat range if you dont want to
Good to know
  • 1 month later...
On 4/27/2023 at 3:18 PM, slowrider said:
Think I found the answer BP5ES
NGK BP5ES
Champion N11YC
Have been the recommended spark plugs to fit to a Sherpa T since day one.
