Beta Rev-80
ryan218
sound like the problem our moped-sidecar :chairfall: bodge we made. It was completely solid and had seized. probably due to us putting remote control car petrol in it :chairfall::chairfall: .
Take the cylinder head off and check the rings arent broken and are sat properly.
If they are take it to a local dealer and ask him to check it over
I dont think that it has seized becouse it was running good before he stalled it and when he came to start it the kick start was locked solid. but still keep the ideas comming.
Cheers Ryan :chairfall:
Edited by Ryan218
Have just rebuilt engine on my sons 04 80, drain water out, remove water pump housing, and clutch slave cylinder.
Lay bike on it's side to save draining gear oil, remove kick start and casing, you should then see whats wrong as its a simple arrangment.
Don't over tension kickstart return spring when you put it back together as this can brake the return stop inside. :chairfall:
If you need to remove the clutch basket just undo the 15mm bolt in the middle and the whole assembly will come off, you dont need to take the plates apart. :chairfall:
