Gas Gas txt 280 pro clutch slip
Hi all
live got a 2003 gas gas 280 , I’ve had the clutch replaced when I had the crank case bearing done about two weeks ago
at a trial at the weekend after about a hour the clutch was slipping in all gears , the oil has no contamination , I have noticed that the clutch piston has some Oil seeping out and the oil is turning a black colour could this leak be what the slipping is ie not enough pressure to release it’s a formula clutch and  have been told these are not good and to get a ajp mineral one as this is what should have been on it
regards
Michael
I would of swore the 2002 -3 pros came with ajp's with dot 4 . Either way both the m/c and lower seals need to be compatible. The lower clutch could have been replaced. Probably best to go with both set for mineral oil. Good luck.
Hi thanks it’s got a formula clutch lever and was told gas gas stopped using  because they weren’t any good . Got a Ajp one coming Will give that a try , the oil in there is black so all signs showing it’s a duff piston and seal
Formula master cylinders only came on GG for one year and one year only, 2012. Worn leaky seals will never cause a clucth to slip though, drag yes
Edited by faussy
Lever is adjusted to tight back it off so there is some freeplay  so it can let fluid back into master cylinder
