Spare parts gasgas jt25 1995 help
andrenld
Hello.guys
I am currently looking for new parts for my gasgas jt25 contact 1995.
I am looking for al the bearings in the swing arm and rear shock.
Crankshaft bearings
Al the seals in the engine and cilinder.
Also looking for a lot of new parts to restore the whole bike.
Do you guys have any idea where i can find those parts?
Thanks for helping me
Andre
Netherlands
Edited by andrenld
Most /all the bearings can be bought from a bearing supplier. The number is generally on the individual bearing.  Crank bearings are normally c3 clearance.
  • Thanks 1
Thanks for the information. I will look into this. All the swing arm bearings and seals that i am looking for. Do you know anyone where i can order these. I have search al over the internet but only can find a set for the 98 model
Thanks
Have a look here
https://www.thehellteam.com/technical-support/gas-gas-parts-and-service-manuals
in the parts list section. Usually they have the bearing number in the name of the piece
Edit: i had a quick look, looks like hk2020 and 20-26-4 for the main swingarm, and 6206 c3 fort he main bearings. I would not buy cheap branded main bearings though, always use a reputable brand like skf or fag. For the bushes, you will either have to try and buy them or get them made.
Edited by faussy
  • Thanks 1
6 hours ago, andrenld said:
Great i will see there
Rear Shock rose joint/ spherical bearing in the shock eyes of a GasGas JT model is normally a GE12PW      size ID = 12mm    OD = 26mm   W = 16mm .
