4RT Wasted spark ignition or not?
aussiechris
It appears to be that the 4rt was the first bike with batteryless fuel injection and the test bed for everything else. With regards to your tests and findings, why is the high tick over so critical for the starting procedure?
Hi Chris
These are really good oscilloscope captures you have recorded here and will certainly benefit people when they have an ignition-related problem.
I myself am also a little surprised at how it goes from wasted spark to non-wasted spark in such a short time horizon - I would not have believed this if it were not for your fine evidence here.
I also find your note regarding an injection timing in the combustion stroke just after TDC a bit strange.
But I can also confirm that this matches my captures of injection timing in the compression stroke TDC and which occurs 25 degrees after TDC.
INJECTION_TIME_COMPRESSION_HONDA_4RT_2007.thumb.jpg.8e815995009e2de8a51aee1e1d5d9883.jpg
This is very important evidence of when and how the ignition system works on a Honda Montesa 4RT and other motorcycles / scooters with similar battery-less systems.
It seems that there are quite a few secrets that need to be discovered.
Just keep up the good work.
Regards
Honda Freak
Does this have any relevance to anyone’s data:
Intake valve opens   6 degrees before TDC
Intake valve closes 27 degrees after BDC
Exhaust valve opens 30 degrees before BDC
Exhaust valve closes 1 degree after TDC
It doesn't have much bearing on what we've been discussing but it does show that these engines have a very short overlap (just 7° in your case).  But thanks for posting it.
I'm guessing the cam profiles changed slightly over the years/models.  These are the figures from my 2022 301RR...
14° of overlap in this case.
Wish I understood the data, I have no idea what the red or blue lines indicate 🤣( X axis crank degrees and time?  Y axis voltage?)
That was from my 250 manual. Looks like Honda freak was also been testing the 250.
