dozerash Posted Tuesday at 12:58 PM Report Share Posted Tuesday at 12:58 PM (edited) I’m working on a 1993 Climber that has a tubeless rear wheel. The tire I received with the bike is tube type. Can I use this tire with tube? Would probably have to use a rim lock. Or should I buy a tubeless tire and valve stem or tube? Thanks Edited Tuesday at 12:59 PM by dozerash Quote Link to comment Share on other sites More sharing options...
lemur Posted Tuesday at 01:19 PM Report Share Posted Tuesday at 01:19 PM When I ran tubeless tires on a tube type rim they were almost impossible to bead suggesting the tubeless tire rides tighter on the rim, going the other way around you will have the opposite problem; about the only way you could do it is to glue the tire on the rim and that would both seal in the air and stop the tire from moving on the rim. Is the tire radial or bias ply? Best to buy the correct tire and better to run a radial. Quote Link to comment Share on other sites More sharing options...
dozerash Posted Tuesday at 07:20 PM Author Report Share Posted Tuesday at 07:20 PM 5 hours ago, lemur said: When I ran tubeless tires on a tube type rim they were almost impossible to bead suggesting the tubeless tire rides tighter on the rim, going the other way around you will have the opposite problem; about the only way you could do it is to glue the tire on the rim and that would both seal in the air and stop the tire from moving on the rim. Is the tire radial or bias ply? Best to buy the correct tire and better to run a radial. Yeah the tubeless rim seems flatter than a tube type. I was going to use a tube. Original owner had a tube in it. Probably wouldn’t seal on the rim anymore. I have the IRC trials tires, I think they are radials and directional. Would have to drill the rim for a rim lock which I would rather not do. Quote Link to comment Share on other sites More sharing options...
lemur Posted Tuesday at 08:16 PM Report Share Posted Tuesday at 08:16 PM If it is a radial it will have an R stamp in the tire size, and/or clearly state Radial on the tire sticker. If it does not say Radial or R then it is not a radial tire. Radial tires typically cost more. You can safely run a rear trials tire in either direction on a trials bike, happens all the time. One rim lock might not even do it, you might need two rim locks if the tire does not fit the rim tight, two rim locks on the rear was common in the days before radial tubeless tires became common. If the tire slides on the rim it will typically shear off the valve stem leaving you with a tube that can not be patched. All of that just to run a cheaper tire that performs less, weighs more and is far harder to install. Tubes and rim locks are no longer cheap and you might even spend more coin to convert to tube type compared to just running the correct tire. Tubeless rim and tires have a different bead shape compared to tube type. 1 Quote Link to comment Share on other sites More sharing options...
LaVern Posted Wednesday at 06:35 PM Report Share Posted Wednesday at 06:35 PM On 6/10/2025 at 8:58 AM, dozerash said: I’m working on a 1993 Climber that has a tubeless rear wheel. The tire I received with the bike is tube type. Can I use this tire with tube? Would probably have to use a rim lock. Or should I buy a tubeless tire and valve stem or tube? Thanks I'm from the U.S and I don't mean to be a smartass but, I am not familiar with the term "climber". What does that refer to? Thanks , LaVen Quote Link to comment Share on other sites More sharing options...
konrad Posted Wednesday at 07:33 PM Report Share Posted Wednesday at 07:33 PM It's just an old Aprilia model name. Here's a pic of one: https://www.james-pratt.com/2023/01/working-on-my-very-rare-aprilia-280-climber-trials-motorcycle/ Quote Link to comment Share on other sites More sharing options...
dozerash Posted yesterday at 02:26 AM Author Report Share Posted yesterday at 02:26 AM On 6/11/2025 at 2:35 PM, LaVern said: I'm from the U.S and I don't mean to be a smartass but, I am not familiar with the term "climber". What does that refer to? Thanks , LaVen It’s a Aprilia Climber 280R trials bike. The model Climber was made from 1989 to 1994. I had a 1992 in the 90s, was the first trials bike I competed on. Quote Link to comment Share on other sites More sharing options...
dozerash Posted 21 hours ago Author Report Share Posted 21 hours ago On 6/10/2025 at 4:16 PM, lemur said: If it is a radial it will have an R stamp in the tire size, and/or clearly state Radial on the tire sticker. If it does not say Radial or R then it is not a radial tire. Radial tires typically cost more. You can safely run a rear trials tire in either direction on a trials bike, happens all the time. One rim lock might not even do it, you might need two rim locks if the tire does not fit the rim tight, two rim locks on the rear was common in the days before radial tubeless tires became common. If the tire slides on the rim it will typically shear off the valve stem leaving you with a tube that can not be patched. All of that just to run a cheaper tire that performs less, weighs more and is far harder to install. Tubes and rim locks are no longer cheap and you might even spend more coin to convert to tube type compared to just running the correct tire. Tubeless rim and tires have a different bead shape compared to tube type. It’s a radial tire. I did mount it on the rim, went on a lot harder than a regular rim. I had a heck of a time seating the bead. Tire looks normal on the rim. I don’t think it’s going to move! 1 Quote Link to comment Share on other sites More sharing options...
