smarty156 Posted July 18 Report Share Posted July 18 I need to replace the 2 seals between the exhaust header and mid section on my 2024 TXT Pro Racing. Any advice? Remove header or mid box? I looked at removing the header pipe but can't see how i can get the lower hex bolt out of the barrel as the exhaust is in the way. A normal Allen key will go on but will only turn a few mm before it hits the exhaust or sump guard/frame. Any help/tips much appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted July 19 Report Share Posted July 19 22 hours ago, smarty156 said: I need to replace the 2 seals between the exhaust header and mid section on my 2024 TXT Pro Racing. Any advice? Remove header or mid box? I looked at removing the header pipe but can't see how i can get the lower hex bolt out of the barrel as the exhaust is in the way. A normal Allen key will go on but will only turn a few mm before it hits the exhaust or sump guard/frame. Any help/tips much appreciated. Thanks. Hello cut a bit off the allen key to get in there better and work it slowly then swap it for a normal bolt with two or three washers when you put it back on ...... or use a flexi extension to get on the allen bolt. Quote Link to comment Share on other sites More sharing options...
zippy Posted July 20 Report Share Posted July 20 use the long end of the Allen key to access the bolt. then use a wrench (5mm I think) on the Allen key to loosen. It is easier with "ball-end" Allen keys. Quote Link to comment Share on other sites More sharing options...
smarty156 Posted 20 hours ago Author Report Share Posted 20 hours ago Sorted with a ball end allen key. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
