mcman56 Posted November 16, 2025 Author Report Share Posted November 16, 2025 18 hours ago, Tr1AL said: The 4RT 301RR makes a pathetic 16.3 HP , 1 HP more than a VERTIGO 125 but the 301RR puts out 15.1 ft/lbs torque , where as the VERTIGO 125 makes 8.8 ft/lbs . With that much torque output of the 301 it may be better leaving it with the stock clutch spring set up. 4RT 260 makes 15.6 HP and 13.4 ft/lbs torque Are HP and torque numbers available for the standard Beta 300 4t, maybe with rpm numbers? I have one of those too. In a tight section, the Montesa feels much more powerful so I need to use very little throttle. I thought it was overall more powerful. However, the other day I took it to some open trails with good size hills. There it feels similar to the Beta. I wonder if there is a real power difference or if the fuel injection just makes it more responsive. Quote Link to comment Share on other sites More sharing options...
lemur Posted November 17, 2025 Report Share Posted November 17, 2025 The problem you are noting with the Beta 4T throttle response is they fitted the bike with a CV carburetor. Vacuum operated carburetors rob engine intake vacuum pressure to operate the carburetor negatively effecting both the throttle response and the engine performance, in PGM-Fi fuel systems 100% of the engine vacuum pressure is dedicated to intake of air & fuel, Fi does not exhibit the throttle lag and occasional misfires inherent to the CV carbs normal operation. Quote Link to comment Share on other sites More sharing options...
mcman56 Posted November 18, 2025 Author Report Share Posted November 18, 2025 On 11/15/2025 at 5:24 AM, lineaway said: The plate holds the springs straight. They other wise rub on the towers. The springs are much lighter. Available from Webike. Why do they rub? Do the springs have a smaller inside diameter? Is the plate just slightly thicker with the groove to center the springs. Quote Link to comment Share on other sites More sharing options...
lemur Posted November 18, 2025 Report Share Posted November 18, 2025 (edited) Want to know what will happen after you put lighter pressure plate springs then required in your clutch <- it's going to slip in high gear ranges, same as if you leave 2 of the 6 springs out. Rhetorical question but dimpled steel clutch plates in a wet clutch leaves more space for oil between the plates, do you believe that scenario will make the clutch grab stronger or slip easier 🤔 and with dimpled plates having more oil between the plates and less surface area contacting the friction plates, will that make your clutch feel any lighter to pull at the lever, I think not. Throw in some lighter springs and you have a formula for inducing more clutch slip. Edited November 18, 2025 by lemur Quote Link to comment Share on other sites More sharing options...
jrsunt Posted November 18, 2025 Report Share Posted November 18, 2025 I also think it would slip when removing springs. The 4rt clutch is quite grabby compared to other models, Elf and light gear oils emphasise the issue more so. The early ones with the small master cylinder were particularly bad. Setting the lever up correctly is quite important and the dimpled plates really do help, much more progressive and will not slip, ever. The Mitani clutch pack is awesome, starts in 1st gear and is quite a bit lighter…. expensive too, but a good investment. I believe there are titanium springs for these, not sure if they give a different feel or are just purely for weight saving Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 21, 2025 Report Share Posted November 21, 2025 On 11/18/2025 at 7:26 AM, mcman56 said: Why do they rub? Do the springs have a smaller inside diameter? Is the plate just slightly thicker with the groove to center the springs. The std 300 Beta in stock mode is weak. Beta used to have a bunch of factory parts to make it zing. My son had a 2015 with all the goodies and it was a beast. On the other hand I spent a day riding Ray`s bike and it was a monster, but was quite fun! If you look at the stock plate on the left, you can see the witness marks were a few springs moved off center. Just because you use different springs does not mean they don`t work correctly. The Japanese put alot of thought in the aftermarket parts they use. Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted November 21, 2025 Report Share Posted November 21, 2025 On 11/16/2025 at 8:39 PM, mcman56 said: Are HP and torque numbers available for the standard Beta 300 4t, maybe with rpm numbers? I have one of those too. In a tight section, the Montesa feels much more powerful so I need to use very little throttle. I thought it was overall more powerful. However, the other day I took it to some open trails with good size hills. There it feels similar to the Beta. I wonder if there is a real power difference or if the fuel injection just makes it more responsive. I have not seen any specs for that bike. Quote Link to comment Share on other sites More sharing options...
mcman56 Posted January 3 Author Report Share Posted January 3 It seems like you could use lighter springs with more preload to attain the same pressure when clutch is engaged. Initial force to move would be the same but would increase less with lever travel. Does the 260 use the same springs as the 300? I see the springs but not the plate. Are they still available? https://japan.webike.net/products/24020409.html?srsltid=AfmBOoqgYESkjfxhn34zme3dmDSwGPvYs9Hpdu39pFhoKpODKapkK5Nt Could this be the same. https://jbanyeres.com/product/special-clutch-springs-for-montesa-cota-4rt-and-4-ride-measuring-281mm/ Quote Link to comment Share on other sites More sharing options...
