mcman56 Posted Sunday at 04:16 PM Report Share Posted Sunday at 04:16 PM Has anyone tried a 260 head pipe on a 300. It looks a good bit smaller and I wonder if it would soften the response. I would like my 300 4RT to run more like a Beta 300. Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted Sunday at 06:18 PM Report Share Posted Sunday at 06:18 PM (edited) 2 hours ago, mcman56 said: Has anyone tried a 260 head pipe on a 300. It looks a good bit smaller and I wonder if it would soften the response. I would like my 300 4RT to run more like a Beta 300. If you want less performance to soften response you need a wider bore pipe not a smaller one , this decreases back pressure and therefore lessen low end torque that makes for instant action off the bottom. Its complicated on a four stroke motor. I would recommend you read up on it before trying any amateur tuning tweeks. Honda 4rt with a BETA 4t motor grafted in? Send a message to BANYERES perhaps he may have something to help you get what you want. Edited Sunday at 06:23 PM by Tr1AL Quote Link to comment Share on other sites More sharing options...
lemur Posted Sunday at 07:52 PM Report Share Posted Sunday at 07:52 PM There are an assortment of restrictors available to detune the 4RT all the way down to ~125cc performance ( learner license ). one plate goes into the intake and 3 are available for the exhaust including a different tailpiece that can be riveted on the tail end of the muffler. ... if you really want to detune one it's not hard, the fuel injection will even sort itself for everything except idle screw setting. Quote Link to comment Share on other sites More sharing options...
jrsunt Posted Sunday at 11:03 PM Report Share Posted Sunday at 11:03 PM (edited) I’m not sure you will get a Mont to feel like a Beta. The injection vs carb response is very noticeable. Mapping would be the way to do it, getting hold of a HRC (fully programmable) throttle body may be impossible though. But, it has been done before with various header pipe set ups, there were some posts on here a few years ago. It would be worth a read. I think the standard 250 and 260 header is 26mm and the 301 is about 30mm. There should be plenty of standard 250/260’s available second hand fairly cheap. The 250 pipes did change around 2009 they are slightly longer to accommodate the newer style silencers. Aftermarket headers are about 28mm. Getting the right gasket to fit the combinations might be tricky. Edited Sunday at 11:25 PM by jrsunt Quote Link to comment Share on other sites More sharing options...
jrsunt Posted Sunday at 11:35 PM Report Share Posted Sunday at 11:35 PM Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted yesterday at 04:05 AM Report Share Posted yesterday at 04:05 AM (edited) hanson racing on Facebook sold one on their ebay shop UK for around £450.00. Edited yesterday at 04:07 AM by Tr1AL Quote Link to comment Share on other sites More sharing options...
mcman56 Posted yesterday at 01:38 PM Author Report Share Posted yesterday at 01:38 PM 17 hours ago, lemur said: There are an assortment of restrictors available to detune the 4RT all the way down to ~125cc performance ( learner license ). one plate goes into the intake and 3 are available for the exhaust including a different tailpiece that can be riveted on the tail end of the muffler. ... if you really want to detune one it's not hard, the fuel injection will even sort itself for everything except idle screw setting. Where can you find these restrictors? I have found nothing. Quote Link to comment Share on other sites More sharing options...
lemur Posted yesterday at 03:08 PM Report Share Posted yesterday at 03:08 PM (edited) 2 hours ago, mcman56 said: Where can you find these restrictors? I have found nothing. In the Montesa 4RT parts manual. There are different versions of the muffler and tailpiece depending on what year and model you are working with, any dealer or customer that has done a competition prep on a homologated 4RT will have the restrictor parts. There is also an intake restrictor plate but you don't want those installed unless you want to completely disable about half the bikes normal power. ... the exhaust restrictors are all 18mm inside diameter. On 9/10/2010 at 6:06 AM, gizza5 said: ... Edited yesterday at 03:44 PM by lemur add Quote Link to comment Share on other sites More sharing options...
mcman56 Posted yesterday at 05:44 PM Author Report Share Posted yesterday at 05:44 PM This is a 2018 300RR. I don't see anything like that on the parts diagram. (The power bomb pipe with O2 sensor is for the street version) I would like a softer off idle response. Quote Link to comment Share on other sites More sharing options...
jrsunt Posted yesterday at 08:08 PM Report Share Posted yesterday at 08:08 PM I presume you’re uk based, the street legal or ED and 2ED bikes weren’t really ordered by dealers in the uk as there isn’t a market for them, the 4ride filled that market. The 3ED and 4ED are the competition versions that came more or less ready for trials without having to swap parts. The 4 ride (2ED) does come with the road legal front pipe as well as a 3ED/4ED front pipe in a kit. It was generally swapped for the 3ED parts as it made the bike a lot better. This is only a 26mm pipe as with all the 260’s. The parts list shown by lemur is from a 2005/2006 bike. Which only had to fulfill Euro4 requirements. The restrictor was a very basic top hat design, something that could easily be fabricated to fit the 300 pipe. It may be worth looking in to. If you could find one off the original 4rt it would fit, the cylinder head is exactly the same from the 1st 250’s right through to the current 301rr Quote Link to comment Share on other sites More sharing options...
konrad Posted yesterday at 08:12 PM Report Share Posted yesterday at 08:12 PM (edited) 21 hours ago, jrsunt said: Mapping would be the way to do it, getting hold of a HRC (fully programmable) throttle body may be impossible though. This is very interesting to me! I talked a friend into buying an HRC "Setting Tool" for his 4RT. I'd never see one for sale in the USA, but he was able to get it out of the UK. It's been in my lab for over a year now, as he seems to have lost interest in riding trials. So I have yet to connect it to a bike. It appears to be able to work with any of the non-homologated ECUs (which should be all the 4RTs in the USA). It does not permit unlimited mapping. What it does allow is a "safe" deviation from the map for any given throttle position and RPM range. It works for both fueling and ignition timing. I'm attaching a screenshot below. Edited yesterday at 08:15 PM by konrad Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted 23 hours ago Report Share Posted 23 hours ago 3 hours ago, mcman56 said: This is a 2018 300RR. I don't see anything like that on the parts diagram. (The power bomb pipe with O2 sensor is for the street version) I would like a softer off idle response. Did you read the SCALVINI system discussion that jrsunt put on , It sounds like it will give you what you are wanting or are you on a low budget. Quote Link to comment Share on other sites More sharing options...
jrsunt Posted 23 hours ago Report Share Posted 23 hours ago That is interesting Konrad. What ECU have you managed to connect to? On the silver sticker with the part number there is also a 2ED, 3ED and HRC. The early Repsol 4rt’s were all fitted with the HRC version which was programmable. Due to customers fiddling without proper knowledge of what they were doing some ECU’s were causing headaches for the dealers which in turn resulted in future ECUs becoming locked and then the 2 map switch as a compromise. There are also a few “works” ECU’s about from factory bikes. They connect to the software via a 9 pin plug rather than the usual 4. Quote Link to comment Share on other sites More sharing options...
lemur Posted 23 hours ago Report Share Posted 23 hours ago 3 hours ago, mcman56 said: This is a 2018 300RR. I don't see anything like that on the parts diagram. (The power bomb pipe with O2 sensor is for the street version) I would like a softer off idle response. See the tailpiece part # 23 and see the tailpiece that it replacers with rivets, I have one of those as spare and I bet lots of other do too. The rest of the restrictors are simple to make on a lathe if you don't want to source them as original Honda parts. Quote Link to comment Share on other sites More sharing options...
konrad Posted 23 hours ago Report Share Posted 23 hours ago (edited) 18 minutes ago, jrsunt said: What ECU have you managed to connect to? None. Unfortunately, have not yet even tried. The unit was purchased secondhand, and it came with a variety of example maps (I guess "map modifiers" would be more accurate) including the 300. The concept is the same as that used on Honda's EFI MX bikes. Sorry for the hijack, mcman56. Edited 23 hours ago by konrad Quote Link to comment Share on other sites More sharing options...
