DustyCat Posted 10 hours ago Report Share Posted 10 hours ago Hi, iv got myself a crackin little bike that touch wood is running great. im after making the clutch a little lighter, I shot a nail through my left hand many moons ago and i think I could practice for longer if the lever had a lighter action. any tips or adjustments I can make? Iv seen online about sanding clutch plates and putting washers under springs. any advice would be greatly appreciated. many thanks Quote Link to comment Share on other sites More sharing options...
faussy Posted 9 hours ago Report Share Posted 9 hours ago The txt came in 1999 so it would help to know what year your bike is, if its the earlier <02 type clutch or the later txt pro >02 diaphragm clutch 1 Quote Link to comment Share on other sites More sharing options...
DustyCat Posted 8 hours ago Author Report Share Posted 8 hours ago Oh right, I’m with you, I believe it’s a 2006, it’s red and black and shiny. 😂 Are there any ways to adjust the weight of a diaphragm clutch? Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted 1 hour ago Report Share Posted 1 hour ago 5 hours ago, DustyCat said: Oh right, I’m with you, I believe it’s a 2006, it’s red and black and shiny. 😂 Are there any ways to adjust the weight of a diaphragm clutch? Set the clutch plate pack thickness to the minimum thickness as advised in the manual and also use a AJP Large master cylinder if possible . There are AJP Clutch Master cylinders available with Large and small reservoirs. Also available are Braktec Clutch Master cylinders that are known incorrectly by the trials community as Braketech . Try googling them both and you will find out which is the correct one. Both are dot COM addresses. Use the long lever not a short or single digit mini blade and position the Master cylinder in board along the handle bar toward the handle bar clamps at the top triple clamp. Position the lever so that you are pulling it with one finger at the end near the ball for maximum leverage . Adjust the lever to move away or be nearer the handle bar grip using the 2 X adjusters one on the lever itself and one on the Master cylinder main body as shown in the Owners Manual. That's one way to get the easy pull at the clutch without it getting complicated and more involved plus more expensive. Quote Link to comment Share on other sites More sharing options...
DustyCat Posted 1 hour ago Author Report Share Posted 1 hour ago Ok great, that’s plenty to be getting on with. i was trying to adjust the lever to get it set perfectly tonight and when it’s held right into the grip/bar the bike was still creeping in 1st gear and I think that’s why I’m struggling to find neutral. I will have look at the clutch plates to start. Any ideas where you find a workshop manual? I have been pulling it close to the fulcrum point because my digit is not very long but I will try adjusting the controls around as well. thanks for the advice, really appreciated Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted 1 hour ago Report Share Posted 1 hour ago 32 minutes ago, DustyCat said: Ok great, that’s plenty to be getting on with. i was trying to adjust the lever to get it set perfectly tonight and when it’s held right into the grip/bar the bike was still creeping in 1st gear and I think that’s why I’m struggling to find neutral. I will have look at the clutch plates to start. Any ideas where you find a workshop manual? I have been pulling it close to the fulcrum point because my digit is not very long but I will try adjusting the controls around as well. thanks for the advice, really appreciated Hello Manuals available at ww.thehellteam.com/tech support/gasgas info. Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted 1 hour ago Report Share Posted 1 hour ago Also Video workshops at TRIALS PARTS USA on Youtube Quote Link to comment Share on other sites More sharing options...
