Gas gas txt clutch
DustyCat
Hi,
iv got myself a crackin little bike that touch wood is running great.
im after making the clutch a little lighter, I shot a nail through my left hand many moons ago and i think I could practice for longer if the lever had a lighter action.
any tips or adjustments I can make? Iv seen online about sanding clutch plates and putting washers under springs.
any advice would be greatly appreciated.
many thanks
5 hours ago, DustyCat said:
Oh right, I’m with you, I believe it’s a 2006, it’s red and black and shiny. 😂
Are there any ways to adjust the weight of a diaphragm clutch?
Set the clutch plate pack thickness to the minimum thickness as advised in the manual and also use a AJP Large master cylinder if possible . There are AJP Clutch Master cylinders available with Large and small reservoirs. Also available are Braktec Clutch Master cylinders that are  known incorrectly by the trials community as Braketech . Try googling them both and you will find out which is the correct one. Both are  dot COM addresses.
Use the long lever not a short or single digit mini blade and position the Master cylinder in board along the handle bar toward the handle bar clamps at the top  triple clamp.
Position the lever so that you are pulling it with one finger at the end near the ball for maximum leverage .
Adjust the lever to move away or be nearer the handle bar grip  using the 2 X adjusters one on the lever itself and one on the Master cylinder  main body as shown in the Owners Manual. That's one way to get the easy pull at the clutch without it getting complicated and more involved plus more expensive.
Ok great, that’s plenty to be getting on with.
i was trying to adjust the lever to get it set perfectly tonight and when it’s held right into the grip/bar the bike was still creeping in 1st gear and I think that’s why I’m struggling to find neutral.
I will have look at the clutch plates to start. Any ideas where you find a workshop manual?
I have been pulling it close to the fulcrum point because my digit is not very long but I will try adjusting the controls around as well.
thanks for the advice, really appreciated
Hello Manuals available at ww.thehellteam.com/tech support/gasgas info.
Are you 100% sure it's 06? The reason im saying that up to 05 they had a heavier belleville spring but in 06 they came with a lighter spring. A dragging clutch may hint at too thick of a clutch pack which also makes the clutch heavier. Personally i wouldn't waste my time playing about with master cylinders, they all use the same size piston and the differences are negligible
Thank you for the message, I was told it was 06’ but the V5 came through the door and it’s a 55 plate reg. So it could be a 05.
so you think I strip it down and measure the thickness of the clutch pack and if necessary replacing the discs and the spring plate?
