mr neutron Posted 9 hours ago Share Posted 9 hours ago (edited) Hi, All! Working on making my recently purchased 1974 TY250 rideable. I'm doing repairs from probably decades of neglect, abuse, and a bit of "Hillbilly Engineering" from the previous owner(s). At the same time, I'm making a few minor "upgrades"; like the Sammy Miller wide footpegs that lower and move the pegs slightly rearwards. This requires removal of the swingarm bolt. While that bolt is out, I thought I'd look into replacing the grease nipple and the pivot bushings. I got the swingarm bolt out after somewhat of an epic battle. Now I'd like to get the long inner bushing out; the one sorta shaped like a long dog bone that goes completely through the swing arm pivot and the plastic bushings. After that, I'd like to replace the plastic bushings, seals, and such. But that long steel bushing I tried to describe above is really, REALLY stuck in there. I don't want to bugger it up as I need to reuse it. How is the best way to rmove this, without doing any harm? If I had a lathe, I'd turn some barstock with a step in it to use as a driver, and maybe try pounding/pushing it out that way??? Any tips from those that have done this before? Thanks, Jimmie Edited 9 hours ago by mr neutron correct some spelling mistakes........ Quote Link to comment Share on other sites More sharing options...
mr neutron Posted 6 hours ago Author Share Posted 6 hours ago (edited) Okay, I guess I "panic-posted", THEN decided to think........ I recall having done something similar with a length of all-thread rod, some washers, some nuts, a sleeve or two, and used all this stuff similar to how a wrist pin puller/pusher works (gudgeon pin????). Will let ya know how it works out tomorrow. Thanks, Jimmie Edited 6 hours ago by mr neutron corrected spelling errors 1 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted 1 hour ago Share Posted 1 hour ago 4 hours ago, mr neutron said: Okay, I guess I "panic-posted", THEN decided to think........ I recall having done something similar with a length of all-thread rod, some washers, some nuts, a sleeve or two, and used all this stuff similar to how a wrist pin puller/pusher works (gudgeon pin????). Will let ya know how it works out tomorrow. Thanks, Jimmie I'm sure that your puller idea will work. In case this is your next question, the plastic bushes can be hard to get out but they will shrink and fall out if you heat them up with a flame hot enough to burn the paint off the pivot tube. 1 Quote Link to comment Share on other sites More sharing options...
