May 1, 200620 yr Does anyone know what the standard final drive gearing is for a 240, I've been told its 10:39 but the handbook I have says 12:39. I'm using 11:42 at the moment which is what was on the bike when I bought it, what does anyone else use/recommend?
May 1, 200620 yr I run my std 240 on 10/39. I also have one with 11/41 and cant really tell the difference. I also have a 245 engine in a 240 and run that at 11/44 which is probably a bit too low. I think 12/39 is too high as I like 3 gear climbs every now and again! Lee
May 1, 200620 yr Not riding a trials bike for almost 30 years before I happened across my 240 , And being a old school type of rider , I changed mine from 11/39 to 10/44 and for my slow style it works great. The fantics gearbox ratios are close enough that I wanted to set it up so 2nd and third would be my primary section gears in twinshock and modern events . But I have found it is a little low for the modern section's . But I still like it where it is !!!! Cheers Glenn And yes 12/39 was stock ! way to fast for my likes !!!!!!!! Edited May 1, 200620 yr by axulsuv
