rev. victor Posted June 8, 2006 Share Posted June 8, 2006 Had a mild crash over the weekend on my 99 321 TXT. Was a tough section but not terribly dramatic. After going down I realized something was amiss with the steering. I looked down and saw that my top triple clamp was about 1/2" forward of where it should be. A closer examination revealed the steering stem had sheared off right above the top bearing. My question is this a weak spot for GG? Other than staying upright anything I should do to not repeat this? Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 8, 2006 Share Posted June 8, 2006 Replace it with a steel one! Quote Link to comment Share on other sites More sharing options...
perce Posted June 8, 2006 Share Posted June 8, 2006 I saw one of that model Gasser folded in half, the lad had hit a ditch when at full chat in sixth. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 8, 2006 Share Posted June 8, 2006 The steering stem is intended to shear before the forks or frame get bent. Instead of forking out big $$$ for new frame or new fork tubes, the steering stem is relatively cheap and easy to replace. Yes making a steel one would probably stop it shearing in a similar crash but if you want a trials bike to weigh 65kg, easily damaged chassis parts are part of the deal. Alternatively the same part could be made from titanium at huge expense but who would want to pay megabucks for a trials bike that was slightly more crashproof? Quote Link to comment Share on other sites More sharing options...
gasgasteve Posted June 10, 2006 Share Posted June 10, 2006 hi happened to my 321 99 last week put new bearings in while it was in bits aswell Quote Link to comment Share on other sites More sharing options...
