2011 Sherco 250 carb
#1
Posted 08 May 2011 - 03:54 AM
#2
Posted 08 May 2011 - 07:00 AM
what effect are you trying to achieve?
#3
Posted 08 May 2011 - 03:32 PM
With the current carb i am having some troubles starting it, and it seems to be taking a longer time to rev down (carb is not dirty, and there is no air leak). I have adjusted the needle and changed both the pilot (36) and the main jet (118).
I want to smooth out the power from bottom to top. The main thing is I want to know if anybody has used a keihin yet.
#4
Posted 08 May 2011 - 08:43 PM
Very good, no problems.
Fitting is a bit of a task as the choke lever will be too close to the black electrical box.
I made a v shaped block to angle the box forward for clearance, quite a simple cure.
Splatshop sell Keihins and ship worldwide. Thats where mine came from.
#5
Posted 08 May 2011 - 09:27 PM
I'd guess you have a fault condition you need to find first.
Best of balance.
Neo
TRIALS....It's not life or death....It's much more serious than that!!
#6
Posted 09 May 2011 - 03:52 AM
Did you do SSDT, is that you Rich?
#7
Posted 09 May 2011 - 04:02 AM
Yes, it has been done as stated, yet if you want to smooth it, probably not the best bet!
#8
Best of balance.
Neo
#9
Posted 09 May 2011 - 06:00 PM
Just as a check of float height put the bike motor runnimg on a downhill angle..probably fine but it's reported that several in SSDT had fuel starvation problems.dont know which models so it's no help really
Edited by chewy, 09 May 2011 - 06:10 PM.
#10
Posted 09 May 2011 - 11:14 PM
#11
Posted 10 May 2011 - 03:29 AM
I can give you a couple things to try on the Dell. Your mileage may vary.
You might try the 38 pilot, where is your fuel screw set now? Get it below 2 turns with bigger jet.
Take out your choke jet to #70-80 range for better cold starting, as in BC, you will have cooler ave temps. A simple drill bit of 3/64ths will take to #80 as equiv as I recall, little ventured!
Needle clip still in 2 or 3 groove.
I still think that on average rider status, the 26 OKO would be the pick if one desires to vary!
Edited by copemech, 10 May 2011 - 03:33 AM.
#12
Posted 10 May 2011 - 06:07 AM
#13
Posted 10 May 2011 - 10:59 PM
Ok thanks, I will try a 38 pilot if i cant dial in the 36. My fuel screw is at 3 turns out. Thanks again!!
#15
Posted 11 May 2011 - 04:13 AM
AWalton, on 10 May 2011 - 10:59 PM, said:
Oh, for smoothing, try the Boyesen reeds as stated. I seen Tryals Shop had some #665 reeds in their clearance section for $20, listed for old Beta Techno, same as what you might want to try.
