Sign in to follow this
sveson
Which Transmission oil
The manual recommends 0W75 Gear trans oil, but I cant find that oil anywhere. What are you all using?
Share this post
Link to post
75W wet clutch gear oil is pretty easy to get. I see you're in Sweden, so I'm not sure what you have easy access to, but a few options would be:
https://www.motosport.com/silkolene-light-gear-oil
https://www.motosport.com/maxima-mtlxl-transmission-oil
https://www.motosport.com/belray-75wt-gear-saver-transmission-oil
I'm sure plenty of people, as with the GG and TRS, run ATF as well.
Share this post
Link to post
Thank you for your answer. But isnt there a difference between 0W75 and 75W oil? Yes, I live in Sweden so maybe its harder to find the right oil.
I put ATF oil in the bike and after that I think the clutch has gone harder so now I want the right oil.
Share this post
Link to post
Hello sveson, the Spanish factories tend to use a fully synthetic 75W oil in the clutch/gearbox. The "W" stands for winter. Various companies can supply this oil, I am not sure what is available in Sweden, but some of the more familiar ones are GRO, Rock oil and Castrol. I have used ATF for well over 25 years in all sorts of bikes without any problem, always ATF rated to Dexron III. All of the Jotagas here run with ATF. Is it possible that you have had water in the gearbox? Although not a common wear point on these bikes, the water pump shaft/seal may have worn. Bye, Peter B.
Share this post
Link to post
I have taken a bit of interest in transmission oils and the potential influence on clutch action, cold grab, lightness and/or aggressiveness and then related those to viscosity and viscosity index while also respecting lubrication of other rather important parts and bearings. I have tried different oils and listened and read of others experiences and 'gospels'. I have constructed a spreadsheet and sorted by viscosity at 40°C (see pdf attached) from manufacturers specifications (some are hard to track down) and then found a website (see the link on the 2nd page of attached pdf) where you can plot the change in viscosity with temperature - with pictures put into the pdf. Another link on the 1st page of the pdf explains Viscosity Index and it seems to me that for trials where great variations in speed, load and temperature exist perhaps a high Viscosity Index (VI) oil would be appropriate to maintain the optimum viscosity (if we even have any idea what that would be). For my style of riding (no instantaneous huge splat walls) I like progressive and light clutch action in my 2015 Jotagas 250 and I like to change my oil every 10 hours, so I also like to look at price comparisons for similar viscosities and viscosity index. Of course there is no perfect answer as we are all different in our riding ideals but maybe this sheet might give you something more to ponder and try. There are oils on the list that may not be available where you are, in the same way some on the list I cannot get downunder and haven't tried them. If interested, I use Chief Oil's - Mohican ATF Dexron III (and buy 4L for less than the price of 1L of some other oils on the list). But I am no oil expert and none of the above is validated for viscosities and temperature and thus it is all just my thoughts and experiences and certainly not challenging the manufacturers - or the oil experts. So whatever works and is available for you, works for you; in the same way that what I use and have available works for me. :)
Gear Oil comparisons.pdf
Share this post
Link to post
Well researched and written peterh, I also have used Mohican ATF Dex III to good effect with similar change times.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
