iconic558
    512
Posts posted by iconic558
  1. I gota say, my SWM 320 1980 std bar 10mm on the arm was THE best clutch of any trials bike I've owned, modern or old. I rode a new 1982 back in the day and that was fine too.
    Just had new proper cable, proper Domino leavers and perches, steels roughed up with 80 grit, running ATF, set up correctly.....and greased balls oooer.
    • Thanks 1
  2. Wow, I've never seen a C clip to retain a rear shock. Cool idea.
    I took the shocks off to grease up the mounts & fter looking at my shocks closely they are actually quite new, they have 504B on the bottom of them? Compared to the gas Betors on my SWM, they are a little oversprung for my weight.
    These shocks are all black and oil only, no gas, possibly NJB Clubmans?
    I'll give the boys a call tomorrow.
    Thanks for your help guys
  3. Hi Andy, a bit late to the party but hey, so what.
    I've the same bike, a 247C (Competition) and they are lovely bikes, light, small with a very friendly and smooth engine.
    The early ones from June 1978 had front fork spring air assist whereby you could pump a little air into the front end to firm them up. This feature was soon deleted though, as they couldn't get the air to remain in the forks.....sounds familiar to modern MX boys;)
    Mine is heading for a rebuild in week or so, only for a frame repaint as the tank paintwork is still original and they are only original once.
    PS Your air filter is correct.
    • Like 2
  4. Well, Speedy has gone off to pastures new.
    I'd like to thank all on here whom have helped in the past when I've had queries or needed helped, when I was but a rookie SWM owner and not the Uber Anorak Owner I later became:D.
    Martin at Moto SWM needs thanking too, like Dave at BikeTech GasGas it's great when someones business is also their passion.
    Honestly getting parts was far easier than for my late Yamaha WRF's I've owned....chatting with some bored and spotty 16 year, who grunts when distracted from the smartphone is not a fantastic experience I'd like to share.
    cheers guysB), all the best
    • Thanks 1
  5. My 247C has quite a few false neutrals.
    Yesterday at tthe trial the old boys running newer stuff, were fondly remembering that even when new, these Montys's came with some free neutrals kindly donated by Montesa.
    Is there a fix, or a case of "they all do that sir"
    Bless the old girl, she really shone on the loose, sandy hill climbs, such a soft 'n friendly engine but grunty when needed, love this bike.:wub:
    -OXF_eGw9QdRi0edYHH9D96y3utWbs-8N0LNM-wUwS0.jpg?w=600&s=7ba9882af313a2de90e663fd52aa63b6
    yeah I know, no 6th!
  6. Soooooo glad I did the clutch spring mod', when we run the modern mono's the sections around there are getting so tight it's really tough for twin shocks - well it is with my limited ability:P), you simply can't 'ride' the sections without a lot of clutch work at some point, or ya looking at fives.
    Saying that I may lower my gearing, she's on OE gearing and this seems a tad fast?
    My Speedy has been lower to the point whereby 1st is almost redundant but great for the tight 'n tough stuff, and I can change gear in the section without getting a box full of neutrals.
  7. Yup, and a backhoe on the rear end, there's a lot of tin work to hack off it for sure...should lighten it by half a ton....not sure where the other half would from come though?
    But it has a certain charm, there are few things to wonder and enthuse over. For example, I like the rubber pads on the tank, to stop me bashing my legs when I fall off, that is forward thinking, even Beta REVS don't have this cutting edge safety feature.
  8. Betors work fine for me on my Speedy with the caveat of the correct spring rate...If I had I gold plated factory Ohlins front and rear I'd still the same crap rider.
    I've NJB's on my 247 and they are stiff as fence posts...need correct springs, previous owner was a fuller figured fellow.
    Those in the hopping 'n jumping Red Route experts like a Rock Shock around these parts, but I think they could have angle iron rear end and still be competitive...thinking of a Bantam hard tail rider
  9. Theres is a Matchless G5 for sale locally, the erm 'lightweight' series....
    Anyone trialed one, or even know anything about them? I could just use it as a roadbike if it's a complete non-starter...in the trials sense. Bit of a curio thing, pudding basin, goggles , white scarf 'n glass of milk.
    1960 350cc single....the fake unit engine one;)...you know, the one with big bulbous engine cases...similar (same as, bar name tags!) AJS model 8. Or a G2 250cc with 350 AJS 8 engine if you wish.
  10. Scratch the ATF....in this hot weather and a long trial the ATF is getting too hot.
    My bike when hot has a noise as the clutch plates go finally fully home...sort of a rattley grrrup noise which is worse on ATF. Using OE all metal sintered plates.
    Using 10/40 engine now and seems better.
    PS anti rattle springs in place.
  11. 8 hours ago, pmk said:
    I did the polishing on my MAR.  In the past, I have polished other aluminum items and even plastic aircraft windsheilds.
    Depending upon how bad the surface is kind of determines the action to take.
    My OSSA had been stored outdoors for many years.  The surfaces of the engine side covers was corroded, and there were scrapes also.  Same for the rims, hubs, forks and more.
    I was able to glass bead all the parts except the rim.  Glass beading removed the corrosion for the most part, but leaves a blasted textured finish.  Next I used a Dual Action sander, same as for automotive bodywork.  I started with 120 grit and finished with 600 grit.
    For polishing, I secured the item by either clamping or using screws into the wooden makeshift plywood polishing table.
    I then used an electric polisher, with a large knitted wheel.  Foam wheels would work also until the final finish.  Using the knitted wheel, I used Mother brand aluminum wheel polish.  Going from 600 to near mirror finish is pretty easy.
    On aircraft parts I have used other polishes.  Most work well.  Flitz is good.  Simichrome is good.  Met All.  And no doubt others will all give good results.  Often it is simply how much time and effort are you willing to endure.  It is very dirty work.  Once done though, often a simple touchup restores the finish.
    For those doing the tadk by hand, yes it can be done.  To obtain a good result with less effort a low cost polishing pad or wheel in the electric drill can work also.
    If you do use a knitted or fabric pad, use an old screwdriver and clean the wheel often.
    Remember, do not use papertowels, they can scratch the finish, I was using old towels, not the best but they do work.  Microfibre cloths work well also.  Just ensure if you wash the rags, do so outside with soap and water before the washing machine.
    Wow....if Carlsberg did answers to polishing case'sB):) thanks for that
