Hi guys, my front brake still isn't as hard as I would like. I have noticed that my brake arm is at a poor angle to the where the cable meets it. The arm pulls up and flexes sideways due to this.
I also think my brake arm is delaminating and will get it to my welding friend to see if he can beef it up. Maybe bend to out to suit cable and weld plates to it?
It is bad angle normal?
First trial with the old bus tomorrow so more to follow.
Were there any mods for lightening the clutch pull on these bikes? It's not awful but compared to my SWM it's heavy. I have a new cable and its routed properly.
I can see that a longer clutch arm will lesson the pull.
I did speak to a guy at a trial with the most original Cota 348 you are likly to see and he had removed two clutch springs. He told me he had no issues with slippage in top gears?
Looks like a pretty easy job to tidy it up ...I have three bodies - trail, trial as per yours and this more dual purpose body . Most of the time I leave the trials. tank on as it is pretty knocked about and I don't have to worry about it
The old boy I ride with tells me the idle mixture adjuster screw is an air screw on this Amal...yet I've always thought if the screw is engine side of the slide, it must be a fuel screw?
So who is correct?
Fuel screw...wind out for more fuel
Air screw...wind out for more air
Bike is a Montesa 247C 1978 but an Amal is an Amal I guess?
Well, to put it another way, all threads on an SWM twinshock are right hand thread.
...a few bikes have the odd left hand thread, usually found on items such as engine clutch basket nuts, primary gears, front sprockets even the flywheel....my Montesa has quite a few for example and OSSA flywheel can be on later models.
Just thought I'd drop a quick line here to thank the guys at In-Motion.
Was having issues trying to source the correct cable for my Cota 247C.
Was on the phone for 20 mins today whilst the poor guy at In-Motion went thru the possible cable Montesa permutations (lots!) and even went and got a bagged up cable up to measure the free cable for me, on the one we thought should fit, may not of been correct, he wasn't to know before opening it.
Great service and thanks
PS...now if you guys could open a well priced Trade Motor Factors near Diss with '30 minute vans' I'd be in heaven...
Well I couldn't remember when I removing the clutch basket this morning if the nut was RHT or LHT, googling didn't help and as the basket revolved clockwise I thought well it would be LHT....wouldn't it?
But before I got my windy (well main'sy) on the bugger and had an exploding first motion shaft (or would that be input shaft?) I thought I'd better get on the blower to the font of everything 'Speedy Working Motor', his Holyness and the Right Reverend Mr Matthews.
Martin confirmed that the thread was indeed RHT and that are no 'trick' threads on an SWM...so hopefully the next person with the same problem will hit google and find this thread and think ahh that was handy
OK, I think I understand this tortured way of screwing an engine together. It appears that the head is secured to the barrel by studs coming off the barrel, barrel is then secured to the crankcase via studs coming off the crankcase to tubular nuts with allen fittings..correct?
...and these barrel 'nuts' frequently sieze?
...is there anyway to apply say Plus Gas or WD-40 to these problematic nuts on a regular basis to avoid any future issues or are the nuts blind being covered by the head?
....hope that all makes sense
....for the love of Mary, just what have I impluse bought?....metal on metal clutch plates, clutch springs held on with pins, brass clutch thrust bearings, odd sized pistons made from Unobtainium, tapered front sprockets, flywheels needing Cornish Beam engined sized pullers...anything else to add to the party?
But the old girl really is growing me, we seem to be a having a love/hate relationship, sort of takes me back to the 80's when I had a Spanish girlfriend. Lovely to look at, body to die for. But somewhat strangely wired with a few handling quirks, excentricities and surprises.
So today I'm in love, te quero mi moto mas bonita...yesterday we were talking who had the house...
What's the situation with the fuel tank/seat unit interchangablity between the older Cota's of all flavors, say 1974 onwards?
I notice that 247 have single downtube frame whilst the 348 have a twin downtube so the frames can't be the same, so my thinking is that 247's don't cross over to 348?
Also, did all UK spec' Cota's have false 'tank tops' with a metal tank under the cover, was there a cut off year? My own 247C is 1978 yet has a glassfibre tank.
I know a metal fuel tank was mandatory for road use until the late 80's (a SSDT question there) I believe but then again, not all UK spec' trials bikes had metal tanks, Fantic for example were all plastic when SWM's ran a metal tank if UK spec' unless I'm mistaken which I often am.
Been poking around the Cota 247C (1978) and it would appear that this bike may originally of come with a red frame.... although the top coat is currently black.
Now I do know that some manufacturers used some odd primers. Take SWM, they used blue primer for black frames (and maybe black for Pernod frames being Italian) so maybe Montesa could of used a red primer?
Also, I sell cars for a living and sometimes the factory 'undercoats' are really quite strange compared to the top finish coat....bright whites under reds, yellows unders greens and blacks etc.
Any ideas from the forum 'Montesti'...I read that in an early 70's test of an old 247
Cota 247C clutch lightening mods?
in Montesa
Ahh, good point on the decompressor, I use one on my Speedy, best thing ever fitted to a trials bike in my opinion.
Kick start shaft....isn't it the later models...left hand chain run that are impossible to source or is it indeed all of them?
