Just started a long overdue restore on my TY175 in Australia. The engine will be rebored with a Wossner piston.
Is there any differences between the model 525 barrel and the 1N4 barrel? I have a spare 1N4 barrel that will take a 1st oversize rebore better than the 525.
The frame number suggests you have model 191. '77 to '78 Sherpa T 350. This is great website listing models with pictures. http://cemoto.tripod.com/bultaco.htm
My brother in Australia just purchased a TY with 125 stickers on it. Frame number 5890047-- and engine number is just 589, nothing following. Bore is 66mm so guessing it's a 175 bore. . I have searched the id tables but can't find a model 589. Anyone any ideas what year this may be? And should it be a 125?
Following worked for me on my 199A and 199B. I used fibre clutch plates, M49 springs (shorter and softer), backed spring adjustment nuts off all the way possible just short of touching case. Made my clutch one finger with no slip.
I changed the fork seals and put 180ml of 10w in each fork leg. I will drain and recheck. I too have never seen this before. I took the nut off the fork cap and the spring and flat disc. I can't see any ball bearing. I have swapped the caps with my other 199B so will test ride and see. Thanks again.
I have a 199B spitting fork oil out of the vent holes in the caps. I am used to a little around the holes but these are spitting oil onto the tank and engine etc.
- Any ideas how to fix this?
- How do the caps come apart to clean the vent valve?
My model 10 over here in the States has that same bracket. Makes sense that's where a stand could or should go. I have never seen a picture of a m10 with a side stand fitted?
Just wondering if anyone knows what type of rear hub this is in the picture. It isn't like any Bultaco one I have seen before. They are the wheels from a Sammy Miller frame with a M49 engine. Rims seem to be the Bultaco shoulder type rims. Thanks for any help...
I am rebuilding a M49 series one. I bought it in pieces and everything is just about back together but i seem to be missing the washer that sits on the gear shaft seperating it from the side case. I looked in the parts book to confirm there should be one there but dont have sizes. Would anyone have one to measure me the outside diameter, inside hole diameter and thickness? It is the earliest M49 with the oval side cases.
2015 4Rt Oil Leak At Waterpump.
in Montesa
I have gear oil coming out of the waterpump inspection hole so guessing the seal is leaking on gearbox side of pump shaft.
Bike has about 1 hour of use......
Anyone had this happen before?
Anything I should look out for or check when replacing the seal?
Thanks
Mark G
