You have answered your own question - "It obviously works" So there is no problem,the valve gear only needs to be wet, too much oil in the head area will encourage leaks and blue smoke. Have you got a copy of the Rupert Ratio Unit Singles engine book,if not I'd suggest its a good idea. Loads of info in there.
Cub barrels aren't exactly scarce,if machining is not an option in SA why not contact a supplier here in the UK to send you a replacement with matched piston ready to go ? If the crack does open up and bits make a break for freedom you are going to trash alot more of the engine.Bottom end rebuilds are not cheap.
Yes, the hunting tooth. But trials chains don't run in an oilbath so any effect would be unmeasurable.
Funny you should mention the hunting tooth - Reminds me of the bevel drive in the MHR Ducati I had. In that situation it was worthwhile. I last thought about it when I saw the wear on my WW2 Matchless cam gears,it was very obvious which teeth did all the work. But on a final drive chain,exposed to even road crud,I can't see any point in worrying.
Nice bike,looks like Ethanol has buggered all the plastic pipes - It will do the same to the fuel tank too.Looks like a Sammy Miller tank / seat unit like I had on my last TY250,the Ethanol wrecked it... The footpegs have been moved back, they are now where everyone seems to have them. I don't know anything about the early 250 motors, FeetupFun is the man who really knows about them.All I would say is that the Ty250 is just about the best twinshock trials bike you will get in most respects.Mick Andrews and Yamaha got their sums right back in the day,and there is plenty of support and knowledge around to make them even better now.
Maybe you need to find a different local welder. Visually most materials should be identifiable, if not a magnet will be a start,applying a grinding disc gives plenty of clues,even down to the colour of the sparks if its a ferrous material. Good job its not a structural repair I'm thinking...
After riding the Bath Classic trial on Sunday I'm having second thoughts.Once I got used to how it rides again I got on really well with it and enjoyed the 2 stroke zap - Which was just what was needed for the A route of the Bath trial.I think the problem is that I so rarely ride it,even my little James is more like a 4 stroke with its huge brass flywheel, the BSA and AJS both plonk superbly which suits how I generally ride. So because there are so many other projects in the workshop I've decided to leave it how Yamaha and Mick designed it back 40 years ago. Just make sure I do some practicing on it before I use it for another trial.
From memory that looks the same as the one I'm running. I'm actually going to ride a trial on it on Sunday,maybe I'll take the cover off after that and have a measure up,see what will fit.
What model ( A B C.. ) of TY is your flywheel from John, the B model flywheel is heavier than he rest of the model.
Guy
Hi Guy, I think its most likely a D model, but its built up out of junk basically. The bike was a non runner from a breakers yard and I built the engine from boxes of bits that contained about 3 incomplete engines... What I was thinking of doing is to turn up a new band on the lathe as heavy as I could fit in,and gradually trim it down until I like it.I think maybe I'm expecting too much from it really,but it will be interesting to see what happens.
the cranks/flywheels are ridiculously heavy in Yamaha 250/350 motors.
Funny you say that,I'm thinking of adding more weight to my Ty250 flywheel, I rarely use it and find it too easy to stall - I ride without the clutch if at all possible. It just doesn't have AJS flywheels !
Why wouldn't anyone just drain tank and carb for long term storage ?
Absolutely, its usually easy on a bike. Strimmers and chainsaws aren't easy to do that on, the Aspen fuel has a 5 year shelf life. The fumes from Aspen are much less harmful too,Network rail are allowed to use it for pertol engined whacker plates in railway tunnels,which the HSE had previously stopped them from doing.
Section Swept, as with Metisse I agree with most of what you said apart from some of the Yamaha comments. The main thing being the way they steer, they are very good - one thing that the Majesty frames did not alter was the steering angle,even today many riders try to improve them by using leading axle forks from the mono's - most go back to the originals. Mick did know what he was doing,and Yamaha were sensible enough to listen.
Also its only the outer clutch and magneto covers that are magnesium, the main crankcases are aluminium alloy that welds beautifully. The outer cases can usually be repaired nicely with JB weld or similar. I can't understand why you think they are difficult to work on... You want to try an AJS.Matchless motor if you think Yams are bad.
Couldn't resist commenting on this David. I've had and been riding TY Yams since 1987. Had loads of different bikes,but only ridden one Ossa - It was Mick's own highly modded bike. It felt right and very familiar straight away,apart from running without a tickover which took a bit of getting used to.
For the average owner I think the Yam has it , simply because they are so right to start with and are so easy to look after and repair.(Very rare to need repairs unless a farmer has had hold of it for years rounding cattle up with it.)
As Faussy says, just get them done at Philpotts. They straightened and rechromed my AJS forks nearly 10 years ago,its done a lot of work since then and isn't very well looked after,they are still perfect.
Many thanks to those who came along and rode or helped out, we raised £457 for the Friends of Huck. Our next charity trial is on the 22nd of September at Ayford farm near Marshfield.
As per the title, we are running our next charity trial this Sunday July 14th at Star farm near Marshfield on the A420 Bristol to Chippenham road. All proceeds from the trial will go to the Friends of Huck Charity.
We will be running a 4 lap, 10 section format, for all Pre65 and twinshock classes. Three routes to suit all abilities,but nothing too tight or scary. No mono's. There will be a burger van in the car park ,plenty of level,hard standing.Postcode for the event is SN14 8LH. Please come and join us. 11am start. https://joncvsv8.wixsite.com/ashwicke
Baldyjohn
in Pre-65 Bikes
http://www.ratiopublishing.co.uk/
