looking at some other breather pipes on gas gas bikes, where it is attached to the bike ours is loose, where as on my mates bike it is stuck/solid to the bike, so think it might be coming from there, perhaps my lad has hit a rock or something and loosened it
might try and redirect the pipe so it's end is higher, see if that sorts it otherwise will have a good look on Monday, hopefully I will sort it, praying it's not the seals
we don't have any problems with ours, use putoline atf change it after about 5 trials including a few practises in between, this on a gasgas 125 2011 no problems at all, touch wood
Hi i was trying to swap the stantions today on my fantic 200, when i took the internal bit apart it sprung all over the place, i've been looking for a diagram of the internal bits of the forks, to see if i have everything and also if i've put it back together correctly
does anyone know where i can find a picture of it , i have some sort of a manual but doesn't show the fork workings at all
Hi i have been using putoline ATF oil in it, but have heard from somewhere about using comma ATF oil, would you use it in your bike, what do you think, is it any good, don't want to do it any damage
thanks for your replies, i've managed to get the top off, I heated it and it worked great, only found one seal in and a washer and circlip, haven't taken it any further to bits, yet am i likely to find another seal or would it have been with the one i found already
i'm currently renovating the bike so not putting it back together just yet, got to get them powder coated before that
i'm going to put new seals in the fantic 200, does anyone have any diagrams of how how to do this, or advice on this, do you use 2 seals in each or just one in each leg.
the top nut, on top of the stantion is stuck, just can't seem to undo it, and don't want to damage them
you'll be fine, i'd probably suggest the white route, if game for a laugh you'll enjoy it, if you find it too easy you can move up to yellow next time, my lad rides a Gas Gas 125 in the 50/50 route, if you need any help/advice, i've got a white combo van, and the others are very friendly and helpful, see you sunday!
i've got a irc tubeless tyre, would it work if i was to put a tube in, or would it cause problems, want to put it on to a Fantic 200 rear wheel, any advice appreciated
i have a t reg combo and gets the gas gas 125 and can fit another bike in, facing them in opposite directions, great economical van, i put a seat in the back as well so can take both the sons, the other bike is a txt 50, without the seat would definately get 2 full size bikes in
Idle And Petrol Air Screw?
in Gas Gas
thanks guys for your help, have stripped and cleaned it, going to put it back together then fingers crossed it's sorted
