Here is a link to see if the part numbers are the same.
I have done the exact same swap. Don't really know if they are exact swap but they do fit. I think the 175 shocks have a softer spring rate but someone else will have to fill that information in.
I have a TY175 circa 1976 - mines great except knackered wheels (spokes missing, rims pitted, hubs look corroded, remaining spokes rusty).
I have just acquired a TY250 also circa 1976. It's wheels are in brilliant condition - clean, straight and very recent new spokes
Can I straight swap them so the good wheels are on the TY175? I cannot see any difference but thought I'd ask first? Even the hubs look identical?
I'll probably swap the forks/yokes as well - I've read on here that the 250 forks are more suited to heavier riders (I'm over 100kg) - any advice appreciated.
Are the rear shocks a straight swap as well? Anyone know standard length for TY175 and TY250?
Thanks in advance for your help, advice, criticism (from the 250 fans I expect) etc.
Looking for info on this bike - could not find much on-line (just basic specs).
I'm keen to know if the engine is a Cagiva design/manufacture or if it was supplied by Honda (or another manufacturer) and if so what is the engine also used in (eg XR500)?
I want to try atf fluid in my TY175 gearbox because my clutch doesn't work when the bike is cold and I've read that atf may help (I don't want to pull bike apart if I can avoid it).
So I went to my local autostore (Supercheap Auto - in NZ) and they have different grades/types - some called type 'D' or 'F' (forgot the brand) and Castrol has several versions.
There's a Montesa 310 for sale (Trademe) on the West Coast and I was wondering wether to drive over and have a look. It's $2200 which I reckon is pricey.
I had a TLM200 and it went OK - but drum brakes.
There is a TY350 for sale with a disc front end fitted - but it's Auckland so the freight kills it for me.
Sammy Miller tail pipe, boyesen reeds, uniflow air filter and 27.5 pilot jet made a big difference to my TY175. More grunt especially off the bottom end - usefull if you have to climb straight after a tight turn. I am about 105kg (230+ lbs) and it pulls me around ok.
I got the bits secondhand so not too expensive.
High rise bars on mine and I like them, otherwise I'm bent double and the back is not as strong as it used to be.
I have concentrated on performance rather than looks so I would'nt go the SM tank and seat unit route - I did get just the SM seat cheap secondhand so that went on.
Suggest you look through this Yamaha forum as there's loads of stuff in here - AndyT recommendations have been spot on for me but I think a boost bottle is just that bit too radical.
You should also look at the TY Trials website they know their stuff and have provided me great service.
So another vote for the TY Trials kit. I might have to ring John for pricing.
My TY starts first pop whenever and has never missed a beat so I'm not thinking of changing due to electrical problems. It's more of a "will it complement the other mods"? kinda thing.
More bottom end grunt to haul me around is what I'm after.
I think the only thing holding me back now is justifying the expense.
If I go for it, based on info I have at present, it will probably be the TY Trials kit as I've bought stuff from them before. Great service and great products - maybe this free plug will earn me a discount?
I don't like the idea of mucking around with the carb set up so the 200 kit will probably be ruled out. I'll probably just freshen up the 175.
I have fitted Boyesen reeds, Sammy Miller tail pipe, 27.5 pilot jet and high flow air filter to my TY175. Thanks to some great advice on this forum (especially from Andy.T) it is running great and the improvement over standard is big.
I am considering an electronic ignition kit and would like to hear from anyone that has fitted one to their TY175.
Where did you get it (TY Trials, JK hirst, other)? What cost? What difference has it made?
I'm trying to figure out if it's worth the expense for me as it'll cost (with shipping to NZ) about half what I paid for the bike.
There has been some discussion of more cost effective ways of doing it, i.e. not a complete kit, has any one done this? What are the pitfalls?
kimpybugalugs,I fitted the Boyesen reeds to my TY175 and had to increase the pilot jet from the 25 to 27.5, it did run with the 25 but is better with the 27.5 as the mixture screw is back out to 1,5 turns. I have got an old cigar shape miller tail pipe fitted also. The carb is one of the all important parts and if its not set just right will give you all kinds of problems, have a look on the net and you will find loads of info on how to set them up.
Got all the bits on yesterday - Miller tail pipe, Boyesen reeds, high flow airfilter and bigger pilot jet as suggested by Andy.T. No carb adjustment needed and bike went through it's first trial today with no problems. It's now a lot crisper and more grunt from next to no revs.
TY250 bits to a TY175
in Yamaha
Thanks JC2.
So if I use the TY250 rear wheel and hub on the 175 I'll need to use the sprocket from the 175?
