sorry for this question just found similar question posted earlier, and there is plenty of tips, so i will practice , practice, and hopefully crack it.
contact for BBSA sm.bullock@btinternet.com .They are holding a trials on 10th may at cookes wood, sorry but i dont know where it is till they publish it in T+mx news .They also hold a weekend trial at bills farm in rhodessia 15-16th august.
Directions for pit tip into blyth to A1 towards bawtry take 1st left to harworth big layby on left. If you forward your e-mail address can give better instructions better to be safe.....
Hi there ive noticed that there is slight movement on the front forks (steering )play when i pull the front wheel,while holding the bike. Does this mean a bearing as gone ? or it needs an adjustment ? If i do require bearings can anyone tell me the size that i need.
sorry its been while getting back to you.I was struggling to rectify the problem, so i took the fork to local trials shop,where the mechanic found the bolt at the bottom of the fork was rotating with fitting inside the fork,he finally released the nut and took out the bottom end,no problems found relaced all parts, and managed to tighten up the bolt at the bottom of the fork. filled with new oil checked the damper everything o k.
thanks for video link..i have taken fork apart the spring seems fine no marks of wear and in one piece..but the oil was black and dirty so i was wondering if that could be the problem ?
the oil may have lost its elastisity (if thats the correct term )
sorry it is txt 280 limited edition 03 model. i will like you say have to dismantle to check the spring. i replaced fork seals a few months ago,new oil reccomended amount, didnt notice any wear on springs. will let you know what i discover.
hi there ive just hit a problem while out practicing the front suspension just dropped bottomed out, i can push the suspension right to the bottom,it does return but very easy to push down to the bottom, i have checked seals they seem ok,there is no sgn of oil anywhere on the forks or on the legs.
is there anyone who could advise me on the problem, and hopefully with your help i can solve it........ cheers dave....
Rear Tyre
in Gas Gas
Thanks for that i will get it done this week
