When on tick over nearly cuts out ,i have to rev to stop engine stalling. But when giving it some power the engine does not miss a beat, but as soon as i shut off the engine sounds as though its searcing for more fuel.
Never worked on this type of carburettor before, there is only one screw which i belive to be the air screw.The carb on other bike had fuel & air screw. Can anyone give me some guidance on what to do or what to check , Thanks
As the title says mine have bust on my 2010 300 raga fitted with Marzocchi forks, can anyone give me any tips , or the order in which to perform said task.....Can the action be performed in garage / shed or is it a visit to local trials shop ? with my wallet..
Just been quoted £70 for the pair if i take the forks in not the bike.
Definitely agree re: ATF, its all I've used in my Gassers.
Best bet for draining is to get the bike warm so that the oil is thin and will drain easier and quicker. You'll probably get more out too.
Re quantity: as mentioned book says 550ml but that's madness. As mentioned fill to half way or just over half way up the glass window - obviously ensuring the bike is sat totally flat - this will probably equal around 450ml
Best bet is fill it, run the bike till its hot, stop it and put back on totally flat surface, wait for oil level to settle in glass window and see where it is then.
Re: oil for your petrol I have always ran mine at 80:1 and they're fine although you can run a bit richer if you like but I've never ran one at 50:1
Always make sure you use a good fully synthetic oil and I always use Shell V Power (higher octane)
You may need to adjust some of the carb settings depending on how you will run the bike oil-fuel mixture wise and how it has been ran previously oil-fuel mixture wise.
Other than that should be fine.
Thanks for replys,like you all say half full check glass window,run till engine hot then re-check and any amount from 350 to 550ml it seems been told to use light gear oil, But you all say ATF Dextron . Where to buy and cheapest place please.Also was told to use putoline fully synthetic oil at 65ml to 5 litre of petrol dont know what ratio thats is.What benifit will Shell V Power oil give me ?
Most people use ATF DextronIII oil, takes about 350ml or fill to halfway in the sight glass. I fill mine then run a few minutes and check it when settled.
Forget the owners book it is full of mistakes!
It says put 550ml in the gearbox (it wont go in!) and it also says petrol mix 50:1 when between 65:1 or 75:1 is what works well.
Cheers Rich for reply, what other mistakes may i need to know ?
Thanks for all your replys, but just you know the unbeliveable has happened my bike has been recovered.....
A friend of a friend phoned me to say my bike was in his back yard, he saw a statement id put on facebook,and made a few enquires with the local thieves and located my bike, a few words with them and let him have my bike...
Got there names just got to arrange a little lift into the countryside where one can stumble and break a wrist ever so easily and this time of year is the wrong time to be out at night in your birthday suit ...
Got woke up this morning at 2-20am alarm on garage going off ,dressed as quickly possible and to the garage in record time to find garage door bent open from bottom,the door handle and padlock to bottom right corner entact....But my Gas Gas 280 txt ltd edition 03 model GONE... Bast/ds
Stolen from Doncaster area South Yorks. The bike was red plastics in above average condition .
V.I.N /chassis/frame no VTR*GG*2801 ...........full number available
If anyone out there heres of any info please leave link on here Please....
Txt 280 Rear Wheel Bearings
in Gas Gas
http://www.gasgasmotos.es/manuales/index.htm
check out manual
