50 -
MSN
RONOC88@HOTMAIL.COM
I recently found that I too was missing the spring and ball. I found a spring in a car fuse carried that fitted and the ball from an old trials wheel bearing is the right size. Should the grub screw have a rounded end as i am too missing it. I have replaced it with a short bolt but was thinking over time surely that will wear the shaft? Ta conor
oops, I did read that but obviously missed the first line, thanks anyway. Whats the tool like for holding the fly wheel while tightening?
Does anybody know where I could find the flywheel nut torque figure? Is there a special tool for holding it while tightening? Bikes a 2004 290. Thanks Conor
Water proof, secure, god damn ugly but a good shed if you've got an oul yard somewhere. Link: http://www.mrbox.co.uk/gallery06-used20ft-cont.html Conor
Bike Rack For A 306 Gti.. Gotta Get There Fast !
ronoc88 replied to magicmat's topic in Trials Transport
I agree with rcgods a trailer is a better way to transport your bike, much less stress on the car. I used to have a 306 also and there was a noticable difference in traction with the boot loaded and the trailer on. One thing to note is that the 306 doesnt actually have any springs on the rear. They use a kind of torsion bar system. I know this because I made my bike trailer from the rear axle of another 306. The torsion bars are on splines on either end you can remove the two ends and lower or higher the car on jacks then just pop them back in, its fairly simple. See the attached picture, the trailer in that pic is not the one made with the pug axle. Conor. -
Its a good oul lift getting a bike in the back of one of those jeeps anyway. We had a lend of a van a few weeks ago (a Mitsubishi something or other,) two bikes and gear fitted perfect. I personally think a decent trailer and a car with a big boot is just as handy if not better. Conor
Chaps What chain should I get for my 04 290? Size? type? Brand? Bought an IRIS for my last bike and it snapped after 2 months, dont want the same again. Thanks Conor
Agreed, Very addictive, half an hour later im still playing. -4c,-b,-40,-1u -40,-1u,-34,-2j -4c,l,-4c,-b -40,1s,-4c,l -30,3k,-3j,2m -3j,2m,-40,1s -24,-34,-18,-38 -34,-2j,-24,-34 -1k,1k,-1q,1c 1n,1h,-1k,1k -l,51,-1m,4g -1m,4g,-30,3k -1b,-3b,-1i,-37 -1a,-37,4c,-3h s,5b,-l,51 1g,1j,4m,12 6v,4g,s,5b 4d,14,5l,7 5l,7,6h,-f 6h,-f,7p,-1a 86,-1q,7o,-1a ea,4o,6v,4g 85,-1q,a2,-38 a1,-37,c7,-o a0,-37,c4,-4c c2,-4b,cq,-4i c7,-o,eq,1s cq,-4i,db,-4i db,-4i,du,-4f du,-4f,eb,-44 eb,-44,en,-3j en,-3j,f5,-2r f5,-2r,g2,-1e eq,1s,gt,3j pv,a1,ea,4o g2,-1e,go,-p go,-p,i4,k gt,3j,je,55 i4,k,hl,19 hl,19,je,30 je,30,ko,3p je,55,lo,5v ko,3p,m4,46 lo,5v,po,7b m4,46,p8,4o p8,4o,s7,4u po,7b,sq,7s 11c,be,pv,a1 s7,4u,uh,4p sq,7s,va,6s uh,4p,v8,47 10p,4p,1a2,4p va,6s,10p,4p 1ae,gv,11c,be 1a0,4q,1b3,54 1b3,54,1c6,5n 1b0,h7,1ae,gv 1bq,hi,1b0,h7 1c6,5n,1d0,6g 1d0,6g,1dr,7f 1fv,ht,1cf,hq 1cf,hq,1bq,hi 1dr,7f,1eg,7p 1eg,7p,1fp,7v 1fp,7v,1h6,81 1h0,gg,1fv,ht 1h6,81,1h7,93 1h7,93,1ju,95 1ia,gu,1hq,gt 1hq,gt,1h0,gg 1k2,ge,1j3,gq 1j3,gq,1ia,gu 1ju,95,1lu,95 1l9,g1,1kp,g4 1kp,g4,1k2,ge 1lu,95,1n0,8t 1ls,94,1sj,7g 1mm,fm,1m7,fo 1m7,fo,1lr,fp 1lr,fp,1l9,g1 1n0,8t,1o0,8m 1o0,8m,1oo,8u 1oh,g0,1nq,fo 1nq,fo,1n8,fm 1n8,fm,1mm,fm 1oo,8u,1pp,8l 1pn,8k,1qm,8r 1qb,g7,1pj,g7 1pj,g7,1oh,g0 1qm,8r,1rm,8m 1so,g4,1r0,g7 1r0,g7,1qb,g7 1sj,7g,21m,94 1st,91,1te,8j 1rm,8m,1sl,88 1sl,88,1st,8v 1tg,g2,1so,g4 1te,8j,1uj,8t 1un,fa,1u8,fm 1u8,fm,1tg,g2 1uj,8t,1v8,8j 1v8,8j,207,90 20b,8u,1vv,90 20b,cs,1vu,dg 1vu,dg,1vi,e9 1vi,e9,1v8,eo 1v8,eo,1un,fa 21g,95,23q,92 208,8v,21e,95 222,bi,21i,bs 21i,bs,212,c9 212,c9,20n,cj 20n,cj,20b,cs 23h,b1,22t,b5 23e,b0,22e,bc 22e,bc,222,bi 23r,92,24k,8u 23k,93,242,91 24n,8u,253,8q 24i,8u,257,8o 23i,b1,264,au 23f,b0,23p,b0 257,8o,26c,8f 264,au,271,at 28r,6u,277,89 26c,8f,27i,87 27h,85,2bh,7c 271,at,27m,an 27m,an,285,af 28o,72,29t,7m 285,af,28k,a2 28k,a2,294,9l 295,9j,2ef,9b 2bu,6g,2c9,60 2c9,60,2cg,5n 2cf,5n,2ib,5m 2bg,7d,2bp,6s 2bl,6v,2c0,6b 2mt,98,2ed,9b 2i9,5m,2jo,5l 2jm,5l,2mm,5k 2mm,5k,2uv,5g 2ri,99,2mt,98 2sr,a8,2ri,99 2vq,df,2sq,a9 2uv,5g,365,5h 2vl,9l,2tt,8s 34d,aa,2vl,9l 33s,dt,2vq,df 37n,aj,33s,dt 365,5h,3ci,63 3e1,bs,37n,aj 37t,ak,37d,ab 3ci,63,3kn,60 3kh,b6,3e1,bs 3ko,5t,3lr,5a 3kr,5s,3kg,60 3uu,65,3kh,b6 3rh,5s,3r4,67 3re,5u,3ru,7c 3th,5s,3rh,5u 3rh,5t,3tn,6o 3ri,5s,3t8,6t 3ri,5u,3sq,74 3rh,5v,3sc,79 3tc,5t,4a4,5t 3ur,66,3v9,5s 48p,-8u,47l,-7n 487,-8c,4cg,-5e 4bt,-8j,48d,-5b 485,-5l,497,-52 49v,5t,4b3,5j 4b6,-8u,4cq,-7m 4cp,-6a,4bl,-51 4c3,4o,4db,33 4b3,5j,4c3,4o 4e2,-6u,4gc,-6s 4db,33,4ht,-1f 4f7,-6p,4f3,-58 4gv,-6r,4gr,-50 4gr,-50,4ii,-5d 4ii,-5d,4ig,-6v 4ht,-1f,4kt,-1e 4j6,-73,4j6,-55 4jd,-6p,4k6,-6d 4k6,-6d,4j5,-60 4j5,-60,4ks,-5j 4l5,-5e,4lb,-79 4lb,-79,4mm,-5e 4kt,-1e,4l1,-4o 4mm,-5e,4n0,-6v #-p,-2u 1j,-33 a0,48 eq,-59 j4,s 10a,36 11m,37 1f4,fp 1ic,7s 1ub,e9 1uq,73 1vg,cq 20g,bj 26h,85 2h9,4s 316,92 35q,4m 3p2,44 4hg,-1o Copy and paste that into the dialog box when you click open. Post yours...... Conor
Hey Can videos such as those mentioned above be viewed online anywhere? Thanks Conor
They say a picture tells a thousand words, so here you are. Conor
Thanks for the replys, It certainly would be interesting to find out did RLracer's bike run Ok. In the end I gave in and modified the piston couple of mins with a file, it turned out quite well. Im still not sure why it wouldn't start, spark is still quite weak, my ignition is leonelli but i think some newer/older bikes came with a different ignition. has anybody else found that the spark is very weak? Gasgaser what were the symptons when the piston was back to front? I will try turning off the fuel also. Sound almost too simple. Thanks Conor
Hello I have owned a 04 290 for about a year now and its hasn't given any real trouble until last week. heres the story: Started bike, ran for approx 2-3 mins stoped and loaded onto trailer, 5-10 min trip, bike off trailer wont start. Checked all the obvious, petrol, plug etc. nothing unusual. Bike back on trailer. Upon further inspection it looked like the spark was quite weak, replaced plug no difference. Suspected timing was out checked woodruf key ok. Pulled off the head and cylinder, checked the rings. Rings were very worn piston and bore looked ok. replaced rings, put back together and it fired. Now heres the question. Why did the bike start then just not start, its not like the rings just wore out in 2-3 mins. I bought the bike second hand so never knew that the compression was low, its always just been like that. Takes a good oul kick now to start it, and the extra power is noticable. Decided that I would replace the Pistion and top end bearing while I had it all apart. Problem 2 - My original piston has a semi circular cut out in the skirt at the rear, I bought a new piston from the dealer and it doesn't have the same cut out. When I returned it as I presumed it was the wrong one I was told its ok thats just the way they come now. This seems strange the cut out leaves the inlet port open where as the new pison almost completly covers same port. The bike just couldn't run properly. It would be the same as putting the piston in back to front. Has anybody replaced a piston lately? Is this the correct piston? The dealer has no other and is certain its the correct piston, im considering altering the new piston to match the old one, or reusing the old piston, but that would be a waste of E90. Any thoughts? Thanks Conor
Chaps Just wondering if any of you could tell me which chain i would need for a 2000 GasGas 250 txt? Iris 520x100 RXL
I have searched the forum here and cant find it. Wondering if anybody knows the suggested carb setting for the above bike with a standard carb. Also what is the correct plug gap? The bike is a 04 model. Also the stickers on my bike are a bit tatty is there anywhere you can buy the stickers and would 05/06 sticker also fit my bike? Thanks in advance for and help chaps
Check it out! http://www.alexadex.com/ad/index.py?page=u...ialscentral.com
