Can anybody help. I have broken my kickstart shaft on my JT35 and now need to convert it from a 16 mm to a 18 mm. Has anyone done this conversion - if so all information would be much appreciated.
Information required:
1. The dia of the hole I need to enlarge in the outer casing to accept the new seal and bush
2. The item numbers for the new seal and the new shaft bush
Finally will any kickstart arm now fit the 18 mm spline shaft.
Don't ride it until you pull the drain plug and check for gear teeth particles. It might be as simple as a bent shift fork or as bad as a broken gear. There could be a problem with the shift mechanism but I would advise not to even start the engine until you find out what's wrong. A broken gear could cause VERY expensive damage.
Jon
Thanks Jon
Will strip down first thing tomorrow and have a look.
bmca trials
in UK Trials Talk
Hi there
Can anyone tell me if the bmca are having a trial on sunday?
The web site as dates from last year.
Look forward from hearing from you
wayne
