Rewiring A Usa 2-pin Plug To Uk 3-pin Plug?
I plugged it in and charged the batteries for 12 hours over night. The LED was green and everything seemed fine this morning. The charger was warm to the touch but not hot, most importantly, the bike worked fine...
It has some LED's on the throttle housing which show the power state of the batteries, they were lit up like a Christmas tree this morning so I think all is ok :chairfall:
  • Replies 34
  • Views 54.9k
I suppose that's appropriate!
Bunch of prophets of doom out there.
It has some LED's on the throttle housing....
Ahhhh, so thats where Honda Montesa got the idea from for their 4RT :chairfall:
Details on the label are: -
Class 2 Battery Charger: Model LC3-24-2A
INPUT: AC 100-240v 50/60Hz
INPUT POWER: 57W (Max)
OUTPUT: DC24v/2.0A
Cheers...
class 2 indeed means double insulated (no earth) so it doesn't matter which wire goes to where.
You will be fine on the input voltage as the label says 100-240v
If you are at all worried then stick your multimeter on the output. Should be 24v DC according to the specs.
