toofasttim Posted February 20, 2007 Report Share Posted February 20, 2007 JR's bike - serious mods That occured to me after posting Dabster, I meant JR's bike. Have a zoom into the cases, looks like the spindle goes thru' the back of them. Quote Link to comment Share on other sites More sharing options...
woody Posted February 20, 2007 Report Share Posted February 20, 2007 No, the spindle doesn't go through the engine, it is mounted either side of the engine Quote Link to comment Share on other sites More sharing options...
toofasttim Posted February 20, 2007 Report Share Posted February 20, 2007 No, the spindle doesn't go through the engine, it is mounted either side of the engine So you have two "stub" spindles then? Wouldn't that make the handling "interesting"? Or do the "stub" spindles mate with a female that's been grafted onto the rear of the motor. Pic doesn't show that much detail. Quote Link to comment Share on other sites More sharing options...
woody Posted February 20, 2007 Report Share Posted February 20, 2007 (edited) There is no attachment to the engine. They are just the stub spindles you mention, mounted directly to the frame plates either side but I couldn't see exactly how as it is all very tight. I think just a bolt pushed through the bush from the inside and a nut on the outside. The spindle is so much closer to the final drive than on Vesty's bike. It worked well as JR had some good results on it when the Bult was past it's best and up against 240 Fantics etc. Maintenance nightmare though as just to get the clutch case off looks like removal of the swingarm or the engine.... Edited February 20, 2007 by Woody Quote Link to comment Share on other sites More sharing options...
toofasttim Posted February 21, 2007 Report Share Posted February 21, 2007 Thanks Woody. Quote Link to comment Share on other sites More sharing options...
legs Posted February 21, 2007 Report Share Posted February 21, 2007 JR's bike swing arm pic Quote Link to comment Share on other sites More sharing options...
twinnshock Posted February 21, 2007 Report Share Posted February 21, 2007 (edited) Old Trials Fanatic. I notice from your original photo's that the bike is fitted with an Amal Mk2 carb. This is the standard fit for a 198b (250cc/5 speed box) A 199b 340 should have a Bing. Is the bike a 199b and does it run OK with the Amal? Stuart Edited February 21, 2007 by twinnshock Quote Link to comment Share on other sites More sharing options...
legs Posted February 21, 2007 Report Share Posted February 21, 2007 All 325's 340's from 1975 onwards used a Bing as standard and is much better than an Amal but that is my opinion and will cause another debate. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted February 21, 2007 Report Share Posted February 21, 2007 All 325's 340's from 1975 onwards used a Bing as standard and is much better than an Amal but that is my opinion and will cause another debate. no debate you're right. Quote Link to comment Share on other sites More sharing options...
twinnshock Posted February 21, 2007 Report Share Posted February 21, 2007 I agree with the comments regarding the Bing. This is why I was surprised to see a picture of a 340 with an Amal and questioned if it was a 340 or in fact a 250cc model 198B which had the Amal as standard. And, Legs..................How would you know, I understand that you never like riding these Bultaco thingies Stuart Quote Link to comment Share on other sites More sharing options...
woody Posted February 21, 2007 Report Share Posted February 21, 2007 And, Legs..................How would you know, I understand that you never like riding these Bultaco thingies Stuart oooooohhh - the mark up on your parts has just increased....... Dabster, what about these frames, are they 340? Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted February 21, 2007 Author Report Share Posted February 21, 2007 (edited) Twinnshock the bike is EXACTLY as it was when Legs sold it to me ! At some time, when i get around to restoring it, i was intending to fit a Bing. Need a second mortguage for Legs prices though Actually it runs fine. People who have tried it said it was a bit softer on power, may mean less, than others they had tried but i understand that Bultacos are very sensitive to ignition timing and exhaust condition so i cant really say. As i said when i bought it off Legs it came with an Amal. Perhaps it's his way of getting a little extra out of me He probably will. Edited February 21, 2007 by Old trials fanatic Quote Link to comment Share on other sites More sharing options...
