June 25, 200719 yr hi people how do i know if my gas gas is a txt pro or just a txt , the guy i bought it off said it was an 03 but i dont know if it is i just wanted to know as i need to order some small end bearings have these bikes got different engines ? and were would be the best place to buy these from cheers ryan .
June 25, 200719 yr Yes I agree its 100% Pro. The TXT and Pro are nothing like each other so there's no doubt at all.
June 25, 200719 yr I've got an 03 gas gas txt and it looks exactly the same as that. I was told the pro didn't come out till the end of 2003. Lift up the dust covers on the forks and look at the top of the fork seal. If it's a 38x48x10 then the bike is a txt, not a pro. Hope this helps
June 25, 200719 yr I've got an 03 gas gas txt and it looks exactly the same as that. I was told the pro didn't come out till the end of 2003. Lift up the dust covers on the forks and look at the top of the fork seal. If it's a 38x48x10 then the bike is a txt, not a pro. Hope this helps No, its a pro. You can tell by the Frame.
June 25, 200719 yr The pro was first released in 2002 and called the TXT pro. The TXT ran parallel for about 2 years after that.
June 26, 200719 yr Author your comments are much appreciated i wil have a look under the fork seal within the next few days cheers ryan.
June 26, 200719 yr your bike is definitely a 2002 pro you can tell by the following 1 the rear caliper on the picture is behind the swing arm - on the txt they were above and prone to damage 2 the kick starter is totally different on both models 3 the cltch cover on the txt was i believe a 2 part affair not as can be seen on your pro 4 the plastics are 2002 txt pro as these were what i had on mine which was bought in 2002 when i still had a 2001 txt to compare all the changes to hope this helps
