brutus Posted November 15, 2007 Share Posted November 15, 2007 I ride my Raga on the "rain" position all the time, lot smoother and less stalling. Btw, if you remove the switch and don't shortcut the wires (so leave them loose), the bikes permanent on rain. Quote Link to comment Share on other sites More sharing options...
steveo Posted November 16, 2007 Share Posted November 16, 2007 You are wrong, period. Think the raga has kehin and kokusan (?) which is why I checked if it was a 250. So the switch changes the carbie Nigel, not the timing? or are we back to the 8000 rev thingy. Quote Link to comment Share on other sites More sharing options...
toofasttim Posted November 16, 2007 Share Posted November 16, 2007 Think the raga has kehin and kokusan (?) which is why I checked if it was a 250. Yup the Raga has the above. Quote Link to comment Share on other sites More sharing options...
rosey Posted November 16, 2007 Share Posted November 16, 2007 ...If its a Spanish made switch... you might want to check that the switch works!!!! I was stunned to find that also on the handlebars lives another 'switch thing' that alters the power delivery dramatically. It lives under the RHS grip and is directly linked to the carb with a cable. Works a treat it does!.. No need for this electrical tomfoolery/work of the devil stuff! Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 16, 2007 Share Posted November 16, 2007 (edited) So the switch changes the carbie Nigel, not the timing? or are we back to the 8000 rev thingy. No qiute clearly it doesn't and I wasn't saying it was dumbass. If it is a raga with a kooky ignition and kehin I was suggesting that my view may be completely wrong on THIS model, but that was not what I was refering to or what this thread was about. Try to keep up and on thread. Edited November 16, 2007 by Nigel Dabster Quote Link to comment Share on other sites More sharing options...
piggywiggywoo Posted November 17, 2007 Author Share Posted November 17, 2007 I have now had time to evaluate both settings. My conclusion is NONCONCLUSIVE ,i have not found any noticable difference in the performance. Having said that , if it makes a differnce only at high revs i am unlikely to know. I have now fitted a head spacer which i know from past experience calms the bike. Finally the real solution lies under my throttle hand.if i twist hard full power. Quote Link to comment Share on other sites More sharing options...
peterb Posted November 18, 2007 Share Posted November 18, 2007 I have a 2006 Raga 300, with Kokusan and Keihin ign. On the sunny setting, the two wires to the electronic unit are shorted and bring in another ign map with a more agressive advance. I do notice the difference on this bike, it is faster to respond off the idle and carburation feels leaner. It is much more easier to ride on the rain setting (wires not shorted together). Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
peterb Posted November 18, 2007 Share Posted November 18, 2007 Woops! Just proof read the message, it should read Keihin carb and Kokusan ign. A senior moment! Ta ta, PeterB. Quote Link to comment Share on other sites More sharing options...
rockaria Posted November 19, 2007 Share Posted November 19, 2007 Well I can't tell any difference between settings on my 07 Raga. If it makes such a difference on other bikes then I'm wondering if the damn things even connected! Also, going off on a bit of a tangent, even with the additional flywheel weight added it still seems "light" on flywheel compared to my old 05 250. Anyone know if this model has a lighter crank than normal or is it just a characteristic of the bigger piston to flywheel ratio? Quote Link to comment Share on other sites More sharing options...
hannon Posted November 20, 2007 Share Posted November 20, 2007 i use the rain setting when attempting loose hill climbs, slick rocks, river bed, logs, where traction is important then i will try it again in the sunny setting and i find that the rainy switch really helps Quote Link to comment Share on other sites More sharing options...
steveo Posted November 20, 2007 Share Posted November 20, 2007 No qiute clearly it doesn't and I wasn't saying it was dumbass. Sorry about that, Im probably not the sharpest knife in the draw but it is encouraging to hear that some of the other member riders have the riding skill sense to feel a difference and can use it to the advantage it was obviously designed for. Quote Link to comment Share on other sites More sharing options...
toofasttim Posted November 20, 2007 Share Posted November 20, 2007 Peter B is damn fine rider, which belies his advanced years (actually he dabbled in the world championship for while). Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 20, 2007 Share Posted November 20, 2007 Sorry about that, Im probably not the sharpest knife in the draw but it is encouraging to hear that some of the other member riders have the riding skill sense to feel a difference and can use it to the advantage it was obviously designed for. and other members don't, so that proves what exactly? Quote Link to comment Share on other sites More sharing options...
ikb Posted November 20, 2007 Share Posted November 20, 2007 Obviously its just a "placebo" switch to give the rider the confidence he needs to climb that muddy bank! "Ooo thats really slippy but I'll be OK if I switch it to rain" (Placebo = a medecine without any active ingredient) Quote Link to comment Share on other sites More sharing options...
