slapshot 3 Posted November 17, 2007 Share Posted November 17, 2007 Jack, another method is to go for the "fat lads" wheelie. Put on 10 stone in weight and hang your lardy butt over the back mudguard, touch of throttle and the front will come up, balance comes from shifting the position of your backside and stomach to balance the weight....... 1 Quote Link to comment Share on other sites More sharing options...
finny Posted November 24, 2007 Share Posted November 24, 2007 (edited) Jason Finn 2002 Edited January 26, 2013 by finny 1 Quote Link to comment Share on other sites More sharing options...
ironbelly Posted January 29, 2013 Share Posted January 29, 2013 I know its an old post, but man, how far back can a bike go without the rider hving gravel rash? Quote Link to comment Share on other sites More sharing options...
guys Posted January 29, 2013 Share Posted January 29, 2013 I like this topic. I'm 47 years old and still trying to wheelie like a pro One thing I learned the hard way: When you're wheelieing up hill and the ground suddenly becomes horizontal, your rear wheel will try to overtake the front wheel and you fall off your bike I guess the same thing happens when you roll of a rock on the rear wheel. As stated before, pulling the clutch-lever and/or tapping the rear brake can avoid a lot of misery when things get out off hand Quote Link to comment Share on other sites More sharing options...
0007 Posted January 29, 2013 Share Posted January 29, 2013 The thing a lot of people do when wheelying is when the front end comes up they start to move forward on the bike This changes the balance point The further fwd your weight is, the more vertical the bike needs to be So, what I am focusing on is keeping my body weight back and keeping it in the same place If you move fore and aft you need to adjust the balance point with every change and it just not possible Now I watch where the pros put their weight When they hop on the back tire, the front tire is not really that far off the ground 1 Quote Link to comment Share on other sites More sharing options...
coop650 Posted February 3, 2013 Share Posted February 3, 2013 Even when riding dirt bikes and street bikes wheelies have always been my nemesis. Once I get the trials bike here at the house I plan to practice these a lot. I have always been able to wheelie over a rock or log at speed, but riding a controlled wheelie is something I have always struggled with. Quote Link to comment Share on other sites More sharing options...
jon0881 Posted March 1, 2013 Share Posted March 1, 2013 Ive done a stunt wheelie school on a bandit in the UK which was good but no use here. I think technique is easy but its the confidence that will spoil you. One good tip i was told was to get two trusty friends to lift the front with you on the bike and you get a feel for the balance point for different body positions i.e leaning back, leaning forward. 1 Quote Link to comment Share on other sites More sharing options...
pindie Posted March 29, 2013 Share Posted March 29, 2013 (edited) Increase your fork preload and reduce your rebound damping. Roll along in second or third gear at just above tick over. Dip the knees to compress your forks and as they unload wind the throttle on and the wheel will lift. You won't need the clutch. If need be use a piece of 4x2 as a kicker for the wheel to rebound off as the forks decompress. Once you get small lift you'll have the feel. You can then get higher and further but just cover the rear brake in case. Edited March 29, 2013 by pindie Quote Link to comment Share on other sites More sharing options...
