February 21, 200818 yr After cleaning the airfilter what can i use to oil it i've seen specific sprays but can i use something like WD40 or can you suggest something else apologies in advance im new to all this
February 21, 200818 yr Use a good filter spray like PJ1. Spray it onto a clean filter, work it in and it will go tacky, this will stop fine dust and to some extent water passing through the filter.
February 21, 200818 yr Like Tony stated use a good air cleaner oil designed for foam filters. Some oils are designed for paper,cotton elements. Some other tips are to spray the oil into the inside of the filter and to work it in. Inside meaning the side that is open to outside air. I also run a very light coat of grease around the edge of my filters to help the filter stay in place better during assembly and to create a better seal to keep dust out. Something that is done alot on enduro bikes.
February 22, 200818 yr I should have mentioned on my last post not to over do the oil. You just want enough to help filter the dust out and not risk dripping into intake causing a rich ( oil to fuel) condition
February 23, 200818 yr I get the oil filter oil in a can and work all the way through and squeeze excess oil out do two at once and theres one ready to swap.
February 23, 200818 yr Oil filter spray is a must and the filter cleaner, it dissolves that sticky oil real good. And Nigel is right have 2 filters and your ready for the next day.
