steve1979 Posted April 7, 2009 Share Posted April 7, 2009 Hi guys, I usually change the oil every second weekend, probably a bit over the top, but for all the price of the oil i like to keep it fresh. When i change it there's usually a metallic look to the oil as you would expect really, my question is, would it do harm to pour say 100ml of diesel through the filler hole and let it drain straight through, to flush any metallic grains that would be resting in the sump, perhaps i'm getting to fussy Cheers Steve Quote Link to comment Share on other sites More sharing options...
deckmaster01 Posted April 7, 2009 Share Posted April 7, 2009 hi mate i might be wrong but i think that poring desiel into the engine might damage the oil seals ?i use castrol oil,ride my bike at least 3 times a week for a couple of hours and change the oil evey 10 hours and it se,cheers jamesems fine Quote Link to comment Share on other sites More sharing options...
steve1979 Posted April 7, 2009 Author Share Posted April 7, 2009 Hi again Deckmaster01,lol Yes you could be right, i was concerned wheather it would damage the fibre clutch plates i didn't think about the seals, it was just an idea that popped into my head, i'll just stick with regular oil changes, i use atf dexron III. Cheers bud Quote Link to comment Share on other sites More sharing options...
jandyb Posted April 7, 2009 Share Posted April 7, 2009 Hi The former norwegian GasGas importer always run the engines he had in for service one minute with kerosene instead of oil in the gearbox to "clean it out" as he said. It sure cleaned it out, but I dont know if there was any harm done by it. Kerosene is AFIK pretty much the same as diesel only "cleaner"? -Jan Quote Link to comment Share on other sites More sharing options...
jse Posted April 7, 2009 Share Posted April 7, 2009 HiThe former norwegian GasGas importer always run the engines he had in for service one minute with kerosene instead of oil in the gearbox to "clean it out" as he said. It sure cleaned it out, but I dont know if there was any harm done by it. Kerosene is AFIK pretty much the same as diesel only "cleaner"? -Jan The ATF is a good "cleaner" and actually old mechanics used to add a pint or two before an oil change to flush out an engine before an oil change. The Pro engine has, in a way, a centrifical "filter" to trap small particles. When you take the spring off the clutch pack, you'll see trapped particles in the recess. I like to change my oil every 5-10 hours. It only takes a few minutes and the Pro engine has a lot of extra stuff to lube than a "regular" engine. Jon Quote Link to comment Share on other sites More sharing options...
jandyb Posted April 8, 2009 Share Posted April 8, 2009 The ATF is a good "cleaner" and actually old mechanics used to add a pint or two before an oil change to flush out an engine before an oil change. The Pro engine has, in a way, a centrifical "filter" to trap small particles. When you take the spring off the clutch pack, you'll see trapped particles in the recess.I like to change my oil every 5-10 hours. It only takes a few minutes and the Pro engine has a lot of extra stuff to lube than a "regular" engine. Jon By the way.. Is this You Jon? :-) -Jan Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 8, 2009 Share Posted April 8, 2009 If any debris doesnt come out with the oil its probably not circulating the engine anyway. I'd stick with regular changes. Quote Link to comment Share on other sites More sharing options...
jse Posted April 8, 2009 Share Posted April 8, 2009 (edited) By the way.. Is this You Jon? :-) -Jan Actually, Jan....that is my Evil Twin, who is bent on destroying all forms of accurate advice given to Trials riders regarding problems with their Trials bikes. I, on the other hand, am the Good Twin, and you can believe everything I say............ Jon Yes, that mug is, unfortunately, mine. I do look much better now with the long hair I've grown after the sex-change operation....... Edited April 8, 2009 by JSE Quote Link to comment Share on other sites More sharing options...
jandyb Posted April 9, 2009 Share Posted April 9, 2009 Actually, Jan....that is my Evil Twin, who is bent on destroying all forms of accurateadvice given to Trials riders regarding problems with their Trials bikes. I, on the other hand, am the Good Twin, and you can believe everything I say............ Jon Yes, that mug is, unfortunately, mine. I do look much better now with the long hair I've grown after the sex-change operation....... hehe.. Your looking good. Forever young that is. Well since I showed your face I will be polite enough to show mine. Here is mine. Picture taken when on my first competition got on the podium in a Scandinavian race. Only reason I got on podium was that I was alone in my class :-) -Jan Quote Link to comment Share on other sites More sharing options...
jse Posted April 9, 2009 Share Posted April 9, 2009 hehe.. Your looking good. Forever young that is.Well since I showed your face I will be polite enough to show mine. Here is mine. Picture taken when on my first competition got on the podium in a Scandinavian race. Only reason I got on podium was that I was alone in my class :-) -Jan Well, a win is a win, and you look pretty happy... " Forever young that is". At 67 years old, the joke George Burns always used often comes to mind (I think it was George), when he was almost 100 was "If I knew I was going to live this long, I would have taken better care of my body"...... Jan, what do you think about oil change routines? I've always advised 5-10 hours or after a muddy or wet Trial on the Pro. I've found that a change after a wet Trial is almost mandatory for most bikes as the vent tube will suck water into the cases on a regular basis (like the alternator sidecover does). The Pro engine is a little less vunerable as the vent tube goes up under the tank, rather than down the back of the cases, but I don't like to take chances. I like to change the oil after running the engine a little to get it warmed up and every time I've checked the clutch the cases are clean, so I probably would not recommend a solvent flush. Regular oil changes seem to be the best remedy for a clean engine. Steve says he changes the oil every 2nd week, and that sounds like good maintenance to me. Jon Quote Link to comment Share on other sites More sharing options...
jandyb Posted April 9, 2009 Share Posted April 9, 2009 Well, a win is a win, and you look pretty happy..." Forever young that is". At 67 years old, the joke George Burns always used often comes to mind (I think it was George), when he was almost 100 was "If I knew I was going to live this long, I would have taken better care of my body"...... Jan, what do you think about oil change routines? I've always advised 5-10 hours or after a muddy or wet Trial on the Pro. I've found that a change after a wet Trial is almost mandatory for most bikes as the vent tube will suck water into the cases on a regular basis (like the alternator sidecover does). The Pro engine is a little less vunerable as the vent tube goes up under the tank, rather than down the back of the cases, but I don't like to take chances. I like to change the oil after running the engine a little to get it warmed up and every time I've checked the clutch the cases are clean, so I probably would not recommend a solvent flush. Regular oil changes seem to be the best remedy for a clean engine. Steve says he changes the oil every 2nd week, and that sounds like good maintenance to me. Jon I agree on that. Although I probably isnt that regular I also like to change about every two weeks as it is a very cheep ensurance. Easy and quick operation too. A couple of minutes riding first to get the oil sweet and warm makes it easier. Warming up really does a difference. When draining my 300 before taking it apart this spring I didnt had the chance to start it up first. As it was about 3-4 below zero (celsius of course) in my garage I almost had to lick the oil out of the engine like syrup.. :-) -Jan Quote Link to comment Share on other sites More sharing options...
