steve1979 Posted April 14, 2009 Share Posted April 14, 2009 Hi guy's, i have noticed i have some play in my front wheel bearings on my 2003 txt pro 250 i'm confused as to which bearings i need, there seems to be two types 6004 2rs or 6905 2rs Any help would be much appreciated Thanks Steve Quote Link to comment Share on other sites More sharing options...
jse Posted April 15, 2009 Share Posted April 15, 2009 Hi guy's, i have noticed i have some play in my front wheel bearings on my 2003 txt pro 250 i'm confused as to which bearings i need, there seems to be two types 6004 2rs or 6905 2rs Any help would be much appreciated Thanks Steve Steve, I think the 03' takes the 6004 2rs, both front and rear hubs. Jon Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 15, 2009 Share Posted April 15, 2009 If you can get them out they should have the numbers on them. Quote Link to comment Share on other sites More sharing options...
steve1979 Posted April 15, 2009 Author Share Posted April 15, 2009 Hi guy's, thank you for the replies i'm going to order the 6004's. I've just had a thought perhaps the worn wheel bearings is the reason i keep falling off sigh if only. Cheers guy's steve Quote Link to comment Share on other sites More sharing options...
thespikeyone Posted April 15, 2009 Share Posted April 15, 2009 rears are 6004's but I would check the fronts, just changed mine on scorpa and they different front to back. Quote Link to comment Share on other sites More sharing options...
jse Posted April 15, 2009 Share Posted April 15, 2009 rears are 6004's but I would check the fronts, just changed mine on scorpa and they different front to back. I checked the 03' parts manual and they list the 6004's for front and rear (with the GG forks). The Marzocchi forks take a different front bearing in the later models. Then again, I've found parts manuals to be a "loose guide" at times........ Jon Quote Link to comment Share on other sites More sharing options...
steve1979 Posted April 15, 2009 Author Share Posted April 15, 2009 Hi guys, yes as Jon says the gas gas manual state's 6004's front and rear and also the company i've ordered them from state's the wheel bearings are 6905 for the 2004 on wards so i'll take it they will fit. If they don't when they arrive i'll let you know after i've got my bad words out of the way there not expensive but it's the time thing thats a hassle for me being in Shetland things usually take longer to arrive. Cheers Steve Quote Link to comment Share on other sites More sharing options...
steve1979 Posted April 20, 2009 Author Share Posted April 20, 2009 Hi guy's Thats the front bearings in and to confirm yes they were the 6004 2r, a nice easy job to do as well which is always a bonus, i popped the rubber covers of the sides and packed in more grease as there's not much in there to begin with, i had a look inside the old bearings and they were knackered, all dry and rusty. Cheers Steve Quote Link to comment Share on other sites More sharing options...
