January 30, 200521 yr I was thinking the other day (doesn't happen very often so hear me out). A heavy flywheel is useful once there's a bit of momentum (if you wanted the momentum), but having a lighter flywheel is better for zipping away from a standing start. So....I don't know whether this already exists, but how about a centrifugal flywheel: The bulk of the weight stays at the centre of the flywheel at low revs (held in by springs), and centrifugal force pushes the weights outwards at high revs. I reckon some sort of damping is needed as well to stop the weights flying out to the outside immediately when you give it some quick revs. Does it already exist? Is it a bad idea? Any other comments? Should I get out more?
January 30, 200521 yr Sounds like an explaination of a Raleigh runabout clutch. That worked well enough.
January 30, 200521 yr [sounds like an explaination of a Raleigh runabout clutch. That worked well enough.] Dabster Nice to know that as well as Bultaco you are an expert on Raleigh runabouts. Stuart
January 30, 200521 yr Sounds like an explaination of a Raleigh runabout clutch. That worked well enough. BS is already riding a Raliegh runabout Your right BS, you do need to get out more mate Edited January 30, 200521 yr by Marky G
January 30, 200521 yr Not sure that would work so well on a trials bike, you need a heavier flywheel at low revs too, to help with low down smooth power, essential for finding grip and not too easy to stall.
