October 15, 201016 yr HELP,I have got a hold of a 06 125 pro racing,got it from ireland(a top trials expert)...anyway I drained the engine oil and its exactly like chocolate milkshake but smells like oil.what will I do...I think I will put new oil in and leave it on test..
October 15, 201016 yr While the oil is drained, take the water pump off by unscrewing the three alan screw's ( you don't need to drain the system) and check the water pump seal if there's signs of antifreeze leaking out it needs a new seal. If it does there's a vid on you tube showing how to do this. Also if it needs a seal check the condition of the turbine shaft. May not be the cause but worth a check to rule it out
October 15, 201016 yr While the oil is drained, take the water pump off by unscrewing the three alan screw's ( you don't need to drain the system) and check the water pump seal if there's signs of antifreeze leaking out it needs a new seal. If it does there's a vid on you tube showing how to do this. Also if it needs a seal check the condition of the turbine shaft. May not be the cause but worth a check to rule it out The milkshake is emulsified oil and water. they will not mix at a chemical level so the froth is what you are left with. There is likely to be a pump issue as already mentioned or possibly a leak from the water jacket gaskets on the barrel. Pump seems to be most likely at this stage from collective experience. If you strip the top end have a gasket set ready.
October 16, 201016 yr Author The milkshake is emulsified oil and water. they will not mix at a chemical level so the froth is what you are left with. There is likely to be a pump issue as already mentioned or possibly a leak from the water jacket gaskets on the barrel. Pump seems to be most likely at this stage from collective experience. If you strip the top end have a gasket set ready.
October 16, 201016 yr Author ok thanks, I will have a look but it looks like there has been some movement there because the pump cover is very new looking,
October 19, 201016 yr Very possible that if someone replaced the seal, to have put it in backwards. Devil's in the details.
October 19, 201016 yr The milkshake is emulsified oil and water. they will not mix at a chemical level so the froth is what you are left with. There is likely to be a pump issue as already mentioned or possibly a leak from the water jacket gaskets on the barrel. Pump seems to be most likely at this stage from collective experience. If you strip the top end have a gasket set ready. Generally the frothing will be only related to the W/P seal failure. The base gasket on the cylinder does not have a water passage (only in an old 90's JT 250 model that had a water jacket in the cases). A cylinder head inner o-ring failure will allow exhaust gases into the coolant system and result in coolant loss out the radiator cap, mimicing overheating but can happen when the coolant is not at boiling temperature. An outer o-ring failure head will allow seepage at the head/cylinder junction. Jon
