midlife Posted January 25, 2011 Share Posted January 25, 2011 Picked up my new 2011 250 sherco Saturday.Went to trial on Sunday after two laps had fuel problems bike would only run with choke on. Striped carb found milky sticky stuff in carb, drained tank and filter and found same stuff. Any ideas. Bike runs fine now. Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 25, 2011 Share Posted January 25, 2011 That u George ? Quote Link to comment Share on other sites More sharing options...
midlife Posted January 25, 2011 Author Share Posted January 25, 2011 That u George ? YES Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 25, 2011 Share Posted January 25, 2011 You haven't been artificially inseminating it have you ? Quote Link to comment Share on other sites More sharing options...
greg Posted January 25, 2011 Share Posted January 25, 2011 take it back. Quote Link to comment Share on other sites More sharing options...
midlife Posted January 25, 2011 Author Share Posted January 25, 2011 You haven't been artificially inseminating it have you ? Cant remember Quote Link to comment Share on other sites More sharing options...
ormplus Posted January 25, 2011 Share Posted January 25, 2011 should have taken it back to the dealer you got it from.thats what a warranty is for.willie. Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 25, 2011 Share Posted January 25, 2011 What colour is the air filter oil, might just be excess pulled into the carb. Quote Link to comment Share on other sites More sharing options...
copemech Posted January 26, 2011 Share Posted January 26, 2011 You haven't been artificially inseminating it have you ? Nothing sounds artifical here! Sounds like he blew it all the way back to the gas tank! Double ck that fuel supply can! Oils can separate out in cold weather. Quote Link to comment Share on other sites More sharing options...
geodet Posted January 27, 2011 Share Posted January 27, 2011 I had a similar problem with mine. It seems that they dont flush out the fuel tanks very well when they are made. If you have done that, clean out the carb as well, not forgetting to completly remove the air screw and check the seat. Last thing is replace the fuel filter, the standard item seems to do nothing. I use an item from a Kart supplier on ebay and they are cheap enough to replace about every 4 rides. Since doing all that I have had no problems with mine at all. Good luck Quote Link to comment Share on other sites More sharing options...
midlife Posted January 27, 2011 Author Share Posted January 27, 2011 I had a similar problem with mine. It seems that they dont flush out the fuel tanks very well when they are made. If you have done that, clean out the carb as well, not forgetting to completly remove the air screw and check the seat. Last thing is replace the fuel filter, the standard item seems to do nothing. I use an item from a Kart supplier on ebay and they are cheap enough to replace about every 4 rides. Since doing all that I have had no problems with mine at all. Good luck Thank you just what i thought. Quote Link to comment Share on other sites More sharing options...
