Oset Batteries Lithium (LiPo) Conversion Directions
Hi I feel so stupid as don't really know what you are saying? Iv found a battery it's a lifepo4 24v 10ah and it's just one big battery but they do a 36v one aswel and I was just wondering if that would work ok and last longer? I would love to do the lipo conversion but I think I'm just to stupid lol
  • Replies 497
  • Views 260k
Most Popular Posts
  • ninefives
    ninefives
    Hi, 1st - You want 24v - each LiPo cell gives 4.2v fully charged 3.6v lowest working voltage. So 24/4.2 = 5.7 so 6 gives 25.2v and when depleted to 3.6v you get 21.6v - that will work - so you need
  • mikedufty
    mikedufty
    Depends a bit on what you want from it. I've posted some stuff above about my minimal conversion on a 24V Oset 16. I used two 5000mAh 6s batteries in parallel. While this is nominally a little less
  • NineFives is right, it really is worth changing the connectors to something that prevents shorting them out or accidentally connecting them together. Throw kids into the mix with anything and sooner o
I'm running a 24v oset 16 on 36 volts, and it goes very well.  No modifications, just swapped the battery (and charger).  This thread has pretty much everything you need to know about a lipo conversion if you read back through it, and it is also pretty easy.  The lipos can be dangerous if not treated correctly though, so its probably wise to steer clear of them if you don't think you understand them.
I haven't tried the LiFEPO4, but from what I've read on electric car forums they offer much better performance than lead acid, but not as good as lipo, but are also more forgiving/less likely to burst into flames, so may be good for you.
Ok brill thanks for getting back to me I think I may do the lifepo4 batteries as iv read this whole thread and still don't understand what is what lol. I would be fine with the charging did of it and buying the stuff to do it its just the instalation on to the bike I won't be great at.
The installation for me was just attaching an xt60 connector to blade connectors to match where the oset batteries connect.
A part to connect the lipos in parallel (24v) or series (36V) can be bought from hobbyking.
I originally changed the lipo battery connectors to XT60, but more recently have just been buying adapters for that from hobbyking too.
Then all you need to do is make sure you have plus and minus the right way around and don't short circuit anything.  The XT60s make it pretty hard to get anything wrong once it is put together the first time.
There is also the physical mounting of the batteries.  I just stuck them in the silicone sleeves from hobbyking and strapped them down with the original velcro.  Other people have stuck them in a fireproof bag or even built a metal box for extra safety, really just mechanical.
I can look up the part numbers of the adapters etc if you are interested.
That would be great if you could and a few pics if possible. I also read with lipo u got to install a kelly controller that what I really didn't get as resistors and stuff had to be installed?
If you don't change the voltage the standard controller will work with lipo.  On mine (2007 model I think) it will still work with 36v (9 cells in series LiPo).
I haven't touched anything on the bike other than unplugging the old batteries and plugging in new ones.
I think I read that on some of the later 24v models, particularly the 12.5s the controller may not work at 36v, which would necessitate changing it.
O right I'm running 36v through my 24v at the mo anyway so does that mean all I got to do is wire lipo batteries? If so could you please tell me exactly what I need as I will try and do it this weekend if all I need to do is change the oset spades and link the batteries together. Do I need a new charger and can they be charged in place I'm currently taking out my batteries to charge them
i would still go down the route of using lifepo4 , they can be bought from Hobby king and look very simular to lipo but they do cost a little more. You still will have to wire them up but they are a little more forgiving than lipo, they have very simular performance/size and weight to lipo.
you will need 3 of these for a 36v battery http://www.hobbyking.co.uk/hobbyking/store/uh_viewItem.asp?idProduct=32206
plus a charger and all the adaptors and connecting leads ..
If you are in the uk .. if you do get batterys from hobbyking make sure you get them from the uk warehouse of you will get stung on postage and import duty.
Edited by gwhy
You can save of the cost of the charger and psu if you invested in a bms for the lifepo4 cells this will then allow you to use a standard 36v charger.
Thanks gwty if I buy 3 of those and run them parallel yer? And all I have to do to the bike is change the spade connectors to the others? This sounds great what charger would be best?
NO you run t6hem in sewrial   ,... opps... really drunk :-)
sorry... run them in serial ..
:beer:
if you dont also get a charger ( spesic chaarger ) tehn you would aslo have to get a bms for tehj complet setup...    still drunks !!!!
edir: ask me again when in sober.
Edited by gwhy
Lol ok thanks. So run them in series and I think I will just buy a charger it's only about £15 I think if I'm looking at the right one. So to run them in series it's all positives together and then negative together?
Sorry I ment positive to negotiate to link them and then the end negative to the bike and the other end positive to the bike?
