June 14, 201115 yr hy does anyone no where i can pick up some cheap pro clean or any good substance like this ,i was told if you shop about you can pick up a 5l for
June 14, 201115 yr TFR traffic film remover from most motor factors commonly used for washing lorries is pretty cheap and you dilute it to suit your needs. Some are more aluminium friendly than others. Comma is okay.
June 14, 201115 yr I swear by the cheap supermarket multi surface cleaner, rinse bike, spray cleaner all over, brush in and rinse, works a treat
June 15, 201115 yr Wurth Bike Cleaner is pretty decent stuff. Leaves summat behind which helps the next wash. I'd reckon it works out about a quid a wash I suppose - depending how mental you go with the squirty bottle....
June 19, 201115 yr hy does anyone no where i can pick up some cheap pro clean or any good substance like this ,i was told if you shop about you can pick up a 5l for
June 22, 201115 yr I would recomend Muc off if you buy it off there site you get it alot more cheaper if you brought it else where also they do free delivery on everything
June 22, 201115 yr I've been using This Stuff for years and I swear by it. I dilute it at (at least) 20:1 and apply it with one of them garden spray pumpy things, scrub it in with a brush and rinse off. Much more cost effective in the long term than the majority of any other cleaners I've used. GJ
July 5, 201115 yr i was using cheap fairy liquid type detergent until i tried my mates purpose manufactured bike cleaner , just called, bike cleaner, from chem-jet based in south yorkshire , i was pleasantly surprised how good it was ! if you do a barnsley club trial he's usually there selling the stuff
