tman22 Posted February 22, 2012 Share Posted February 22, 2012 The PHBH26 off my '90 Zero has "TD" stamped after the model number: I need to get a few parts for it and can't figure out if these two letters mean anything. Can anyone let me know if this suffix should be taken into consideration when order for this unit? Looks like the parts can be got from http://www.dellorto.com/merchandise/products.asp?CategoryID=2&PartsectionID=24 but want to make sure. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted February 22, 2012 Share Posted February 22, 2012 PH is the model number B is spigot mount H is the larger body series [L is the smaller body] 26 is size in mm T = ??? D is right side mixture/idle [s is left side mixture/idle] Cheers Greg Quote Link to comment Share on other sites More sharing options...
tman22 Posted February 22, 2012 Author Share Posted February 22, 2012 Thanks, Greg. Appreciate the explanation. Anyone know what the "T" means? Quote Link to comment Share on other sites More sharing options...
pindie Posted February 22, 2012 Share Posted February 22, 2012 Turbo Quote Link to comment Share on other sites More sharing options...
gjbiker Posted February 22, 2012 Share Posted February 22, 2012 I did once find all the info for Dellorto model numbers but can't seem to find it again.... You could try e-mailing Dellorto, they might know? sales@dellorto.co.uk (can't find a contact for the U.S) GJ Quote Link to comment Share on other sites More sharing options...
tman22 Posted February 23, 2012 Author Share Posted February 23, 2012 Thanks, GJ. I'll shoot them an email. Terry Quote Link to comment Share on other sites More sharing options...
tman22 Posted February 23, 2012 Author Share Posted February 23, 2012 Turbo Quote Link to comment Share on other sites More sharing options...
mikethompson Posted February 29, 2012 Share Posted February 29, 2012 Is "trials" too obvious? Quote Link to comment Share on other sites More sharing options...
copemech Posted March 1, 2012 Share Posted March 1, 2012 Wot is BS then? Quote Link to comment Share on other sites More sharing options...
laser1 Posted March 1, 2012 Share Posted March 1, 2012 From the dellorto UK site: T-means Terrific! A note on carburettor model designations. PHBH 28 B S PHBH - Main body type, each body comes in a range of bores. - The effective diameter bore of the carburettor in mm. B - Generally rubber sleeve "elastic" type fitting. A - Generally clamp type fitting. Other letters have no specific meaning - they have certain original applications - if you are unsure which model you need, contact us before buying. S - "Sinistra" - "left" in Italian - Left hand idle mixture and idle speed screws. D - "Destra" - "right" in Italian Right hand idle mixture and idle speed screws. Quote Link to comment Share on other sites More sharing options...
