tonyr6 Posted March 30, 2012 Share Posted March 30, 2012 (edited) hi can anyone help ive tried all ways to get my bike to start cold or hot!!! fresh petrol!! carb cleaned spotless!! new plug etc?? when it does start by bumpstart it runs lovely but leave it and it wont start by kicking it !! have just replaced the kickstart quadrant and idler guess the guy i had it off wore them out but it kicks over nicely now?guess what it wont start!!! any help appreciated Tony Edited March 30, 2012 by tonyr6 Quote Link to comment Share on other sites More sharing options...
toothandnail Posted March 30, 2012 Share Posted March 30, 2012 try a richer pilot jet , fixed my hot start issues , had to use the choke EVERY time hot or cold. Quote Link to comment Share on other sites More sharing options...
tonyr6 Posted March 31, 2012 Author Share Posted March 31, 2012 any idea wot size you used to sort this out ive got 118main and 36 pilotjet??? my leg is killing me takes all the fun out of riding!!! Quote Link to comment Share on other sites More sharing options...
toothandnail Posted March 31, 2012 Share Posted March 31, 2012 Can't remember , it was 3 years or more ago . pretty sure it was just one size bigger. I rejeted to ride in the mountains , started much better , came home changed the main back left the pilot. Statred first kick 90% of the time . Cold with choke , warm just kick it. Quote Link to comment Share on other sites More sharing options...
tonyr6 Posted April 1, 2012 Author Share Posted April 1, 2012 ok cheers will give it a try!!! order 1 in morning !!! just got back from 2hrs in the forest dropped it once took 15mins and about 50 kicks to start!!! still enjoyed Quote Link to comment Share on other sites More sharing options...
19col58 Posted April 1, 2012 Share Posted April 1, 2012 Are you sure the carbs not flooding? Quote Link to comment Share on other sites More sharing options...
copemech Posted April 2, 2012 Share Posted April 2, 2012 I do not wish to sound "too" basic here, yet one never knows. On hard starting issues, start with checking your spark plug. Hard starting can be the first sign of one going, even though it may seem fine otherwise. I fixed a bike this weekend where someone had put a plug init at factory gap setting near .035 in, when set to a proper .025 it worked fine. Fresh plug costs little as compared to the LEG! Quote Link to comment Share on other sites More sharing options...
tonyr6 Posted April 2, 2012 Author Share Posted April 2, 2012 dont want to sound ungrateful any replies are much appreciated, but ive changed the plug and set to 25thou ive had the carb in bits and it is now mint inside im gonna try the pilot jet first?? if not a montesa maybe on the cards Quote Link to comment Share on other sites More sharing options...
smalley250 Posted April 2, 2012 Share Posted April 2, 2012 My old Gas Gas 300 was a bitch to start. I raised the float level and this fixed it. Remove carb and turn upside down, then measure 16mm from the base of the carb to the end tip of the float arms. Previous to this i could lay it on its side and it would flood then be able to start. 1 Quote Link to comment Share on other sites More sharing options...
tonyr6 Posted April 3, 2012 Author Share Posted April 3, 2012 (edited) i will try 38 pilot jet and raise the floats !! what year was yours ?ive got carb off and as i said it was spotless inside!!! will let you all know if any improvement !!!! fingers crossed cos i got my eye on a montesa 4rt Edited April 3, 2012 by tonyr6 Quote Link to comment Share on other sites More sharing options...
tonyr6 Posted April 4, 2012 Author Share Posted April 4, 2012 she gotta go!!! fitted 38 pilot jet and dropped the floats down!!!! checked inside flywheel and cleaned it out !!!! started after about 8 kicks with choke run for 15mins and adjusted carb switched off to answer phone and guess wont start kicked and kicked and KICKED!!!!!!!!!!!!! ????????? Quote Link to comment Share on other sites More sharing options...
laser1 Posted April 4, 2012 Share Posted April 4, 2012 Probably not the issue, but you mentioned you replaced the KS pawl - did you follow the recommended alignment? Sounds like the bike was always hard to start - but thought I would bring it up anyway as something else to take note of to make sure your getting a full spin of the motor. Also - have you had another 300 rider give it a go? They can require a very special kick. Quote Link to comment Share on other sites More sharing options...
tonyr6 Posted April 4, 2012 Author Share Posted April 4, 2012 thanks for the reply yes kickstart all ok kicks nicely now and yes aligned ok!! managed to get it started just now after leaving it cool a little and using the choke?? Quote Link to comment Share on other sites More sharing options...
bmseven Posted April 4, 2012 Share Posted April 4, 2012 There is a definate knack involved I found my 280 difficult at first. Now 2nd kick from cold with the choke on and 1st kick when warm, PS even if I stop riding for a drink break 20 mins later it likes the choke again! 1 Quote Link to comment Share on other sites More sharing options...
tonyr6 Posted April 4, 2012 Author Share Posted April 4, 2012 im working nights tomorrow so weather permitting im off for a ride in the morning !!! will let you know how she performs !! when you start with choke after stopping are you using any throttle? Quote Link to comment Share on other sites More sharing options...
