April 3, 201214 yr Hi all Newbie looking to buy my first Trials bike ( done 4 experience days ) Quick question Has anybody got any experience of these types of carrier http://motorbiketrailers.org.uk/carrier-frame/ My 406 has a towbar nose weight of 80kg Lightest 250 ive seen is +65kg dry, plus normal towbar carrier 17kg Too heavy for my car So looking at this type Any info greatly received Cheers Jody
April 3, 201214 yr Hi Jody You certainly don't want to be using one of those for towing a trial bike Your 406 with a Dave Cooper rack will be fine for any trial bike you choose to strap on to it, the nose weight is for towing which with a rack your not your carrying http://www.davecooper.co.uk/ I don't even notice I have a bike on the back of my A4
April 3, 201214 yr .....you'll shred your rear tyre. I agree with bmseven, get a Dave Cooper type rack. I've used them on everything from a Citroen AX (shouldn't have really ) to current Defender.and they work fine.
April 3, 201214 yr unless your bike is road legal you cant have the drive wheel touching the road its an offence
April 3, 201214 yr Author Think im gonna go with a collapsible trailer........... Cheers for the info boys
April 4, 201214 yr unless your bike is road legal you cant have the drive wheel touching the road its an offence Interesting but it seems a bit strange? A trailer / caravan doesn't need Tax, MOT or insurance which would constitute to it being 'not road legal' so are we all commiting an offence when towing our trailers and caravans? Surely a bike transported in this manner would be classed as being a trailer of some description as is a car when it's transported on a dolly? As long as you comply to the rear lighting / number plate requirements I really can't see why the bike needs to be road legal? More info anyone? GJ
April 4, 201214 yr Because your bike has an engine it would need to be road legal. You would have to remove the chain anyway, so no longer a bike ?
April 4, 201214 yr Did a bit of research and it's all as clear as mud as usual with the jargon in the directives which would probably mean the local plod wouldn't have a clue either (and I don't blame them, who writes that stuff?). Here's a wee bit I found- What is a trailer? A road vehicle, usually (but not necessarily) two wheeled, towed by a motor vehicle.Given the above dictionary definition, it is fairly clear that anything attached to the towball and having wheels in contact with the ground is a trailer. This includes cars on ‘A’ frames and dollies. Bearing in mind that the unbraked towing limit of 750 kgs refers to Maximum Gross Weight (i.e. the figure on the towed cars VIN plate) and not to actual weight, it severely restricts the options. The only cars I know of with a MGW of less than 750 kgs is the Aixam range. These are around 450 to 550 kgs. There are strict regulations on braked trailers and, whilst a braked ‘A’ frame attached to a towed car constitutes a braked trailer, it is not legal for transportation as it cannot comply with EC71/320. With car dollies, the situation is somewhat different. Under regulation 83 of the Road Vehicles (construction & Use) Regulations 1986 (SI.1986/1078) Amending Regulations, a car dolly, with a car in place, will be considered as two trailers. This is legal for recovery but, under the Road Traffic Regulations Act 1984 (Schedule 6) the combination is limited to 40 mph on motorways and dual carriageways and 20 mph elsewhere. Note that there is a very specific difference between recovery and transportation. Recovery is the removal of a broken down vehicle to a place of safety. It does not include removing a rotor arm (for instance) and travelling the length and breadth of the country. The police are well aware of the difference due to the regulations covering Tachographs and Operators Licences. Recovery vehicles are exempt. It is well known that some countries in the EEC tend to overlook the regulations (the UK included) but some countries don’t. The situation regarding enforcement could change at any time and, as a result, the only safe way to transport another vehicle behind a motorhome is on a car transporter trailer. Play safe! Don’t take the risk! The regulations which cover this aspect of towing are:- 91/438/EEC covers driving licences. 71/320/EEC covers auto reverse braking systems and couplings. S.I. 1971 No 450 Part III covers the obstruction of number plates. 94/20/EEC covers type approval of towing equipment and ‘S’ and ‘D’ values. 95/48/EEC covers Masses and Dimensions of M1 class vehicles. E.T.R.T.O. 1991 section 13 covers wheels and tyres. BSAU 113c covers 50mm ball and coupling dimensions. BSAU 24a (1989) covers eye couplings and pin/jaw arrangements. 98/12/EEC covers brake linings and will be implemented in the UK from 1/4/01.And not strictly towing but applicable to motorhomes is EN1648-1 covers extra low voltage installations in Leisure Vehicles and Caravans. In a nutshell, I've given up caring and shall stick to using either the rack or the trailer GJ
