abn70 Posted August 18, 2012 Share Posted August 18, 2012 My 2000 Sherco 250 wouldnt start and after taking off the flywheel one of the contacts is loose. Is this terminal? Looking on websites you cant buy second hand ones and new ones come with new stator. Expensive for a 12 year old bike! Quote Link to comment Share on other sites More sharing options...
copemech Posted August 18, 2012 Share Posted August 18, 2012 (edited) http://www.uk-motoplat.com/home.html This would be your man. On second thought, what are you saying here? Is the flywheel itself coming apart? What contact are you referring to? Post pics if you can. Edited August 19, 2012 by copemech Quote Link to comment Share on other sites More sharing options...
abn70 Posted August 19, 2012 Author Share Posted August 19, 2012 (edited) Thanks for the reply. Inside the flywheel there are metal contacts about 1inch square riveted into the magnet. On one of them is loose. Hope this helps I only know the basics! Edited August 19, 2012 by abn70 Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted August 19, 2012 Share Posted August 19, 2012 I would imagine any reasonable engineering adhesive would sort this. The force, when in use is, after all, going to press the metal harder against the magnet rather than try and remove it. Quote Link to comment Share on other sites More sharing options...
abn70 Posted August 19, 2012 Author Share Posted August 19, 2012 Thanks, I've searched web and cant find anyone with the same problem. Will try engineers in yellow pages to see what they have. Quote Link to comment Share on other sites More sharing options...
copemech Posted August 20, 2012 Share Posted August 20, 2012 The pic as small and I cannot tell much, however it may be a pole piece has separated at a rivet. If the magnet is gamaged, the wheel will likely require replacement. Is this a Ducati ignition? There is likely someone out there with a flywheel. Quote Link to comment Share on other sites More sharing options...
abn70 Posted August 20, 2012 Author Share Posted August 20, 2012 hi, it is one of the pieces with a small "V". The magnet doesnt look damaged so i was wondering if I should look for someone to repair or just "bite the bullet" and find a second hand one? any last advice? Quote Link to comment Share on other sites More sharing options...
gjbiker Posted August 20, 2012 Share Posted August 20, 2012 Like Copey said, the picture is too small to be able to give any advice but on a hunch I would say it's repairable by someone who knows their stuff? GJ Quote Link to comment Share on other sites More sharing options...
copemech Posted August 21, 2012 Share Posted August 21, 2012 Still worth a call or email to Steve at Motoplat UK as he may offer suggestions. Quote Link to comment Share on other sites More sharing options...
abn70 Posted August 21, 2012 Author Share Posted August 21, 2012 thanks for your help, Chis at Splat Shop has a second hand one. I'm new to Trials and new to Trials Central and cant believe how helpful everyone is. 2 Quote Link to comment Share on other sites More sharing options...
copemech Posted August 22, 2012 Share Posted August 22, 2012 thanks for your help, Chis at Splat Shop has a second hand one. I'm new to Trials and new to Trials Central and cant believe how helpful everyone is. That is good then, just replace it. Hopefully there are no other issues with the stator. Quote Link to comment Share on other sites More sharing options...
ham2 Posted August 22, 2012 Share Posted August 22, 2012 Are your main bearings OK? I'm just wondering how your original flywheel problem occurred? Quote Link to comment Share on other sites More sharing options...
abn70 Posted August 22, 2012 Author Share Posted August 22, 2012 How do I check the amount of free play ? The bike had a new stator and only ridden once since. Is it possible the flywheel was not put on properly ? Thanks Quote Link to comment Share on other sites More sharing options...
tony27 Posted August 22, 2012 Share Posted August 22, 2012 How do I check the amount of free play ? Grab the end of the crank & try lifting up & down, you should be able to feel any movement The bike had a new stator and only ridden once since. Is it possible the flywheel was not put on properly ? If the flywheel wasn't fitted right the internal taper will be damaged so I wouldn't think so Thanks Quote Link to comment Share on other sites More sharing options...
gjbiker Posted August 22, 2012 Share Posted August 22, 2012 Are your main bearings OK? I'm just wondering how your original flywheel problem occurred? I'd hazard a guess that it sat for quite a while with water trapped in the casing? GJ 1 Quote Link to comment Share on other sites More sharing options...
