My Seeley Pics
Thanks for that Mark - the old card and tape method eh... effective isn't it, I've made a couple of airboxes like that.
I'm glad you said there is nothing in it as I want to have a go at making one for mine and it is easier if there are no internals. The one fitted to the bike is quite neat but it is steel and I'd like an alloy one. Must get it running first though...
  • Replies 39
  • Views 20.4k
philippe delwiche used to do the the 250 conversion
also a monoshock conversion, with tank/seat rtl-style
another option was a longer 6th gear (30T)
Was this similar to the Gollner Mono TLR's?
tlrs
Can you give some details on the taller 6th gear? Was this done with Honda parts? Are the components still available?
sorry, i have no info on this,
just a copy of the instructions that came with it:
how to modify case & fork to accept the bigger pinion
delwiche monoshock tlr250
Just for interest does the shock work via a linkage?
Gordon
Thanks for the instruction copy. I wonder if it used gears from another Honda model? The quality of the instructions suggest to me that it was not a custom gear manufacturer. (although 20 years ago instructions were not so pretty) A wider range transmission would sure be nice.
I've followed the engine conversion thread with some interest since I've been told that my Seeley has a 250 conversion. Until reading this I knew nothing of the Kondo conversion, and assumed that what I'd got was some one-off possible bodge job special. However, looking at the pic that RS posted I can see that my engine looks exactly the same and might therefore be a Kondo converted engine. It certainly has plenty of grunt
But, who are or were Kondo? Any further info would be very much appreciated.
And who is Phillipe Delwiche?
in his youth, philippe delwiche was belgian trials champion (74(?))
later he proved to be a gifted technician too
clients from all over france & belgium visited his honda shop
the man died in '98, shops closed...
  • 5 months later...
This is my Seeley...bought a couple of months ago, going to do some cosmetic work such as wheel rebuilds, hub powder coat etc.
Open to other suggestions..keep em clean please
Edited by Panomphaean
