February 8, 201313 yr Hi I have recently purchased a beta techno 98 (dougie lampkin 97 replica). Trying to find manuals etc seems to be an issue even for Beta. I found a few available but the info is very blurred and not much use. Can anyone help?? Many thanks for any help. Dave
February 8, 201313 yr All you are going to find is a parts breakdown. You might get lucky and somebody on here will have the one page owners manual. It takes around 500cc trans. fluid. It should have a sight glass. Be careful on the radiator cap as the direction is marked wrong.
February 8, 201313 yr check out http://www.trialsport.com.au/beta/documents.htm for lots of rips of various beta documents i found a scanned in version of my 99 techno's manual on a link somewhere on this forum once, so keep looking
February 8, 201313 yr Author A nice electrical diagram would be nice and an owners manual. I have the parts breakdown which seems to be freely available. cheers rabie - I only had an italian parts list previously.
February 9, 201313 yr 99 manual - here (9.27mb pdf) includes a wiring diagram Edited February 9, 201313 yr by rabie
February 10, 201313 yr Author Thanks for the 99. I'm offshore at the mo so won't be downloading until I get home. I was also having issues with the clutch master and slave. Can't build any pressure with the clutch lever. Checked the seals and they seem fine. slave looks like it may have jammed in postion. Can't see any easy way to extract. do the line have to be primed up the way with a sringe? Where's was the speed sensor on this unit for the read out on the tank? There are 2 bare wires at the back wheel which look suspect. cheers
