chuckindenver Posted April 12, 2013 Share Posted April 12, 2013 so the air screw is in a bad spot. bottom side of the carb. Evo 4Ts use a CV carb. any ideas on a remote adjustment? doesnt any one make a nice one? with a T pipe, even a angle screw driver is a bear to use. Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted April 12, 2013 Share Posted April 12, 2013 jitsie do one with a thumb wheel so turns easily Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted April 12, 2013 Author Share Posted April 12, 2013 is it for the mikuni CV? i dont have any experiance with Rev 4ts so i dont know what carb they use, Quote Link to comment Share on other sites More sharing options...
wright4d Posted April 13, 2013 Share Posted April 13, 2013 I have the same bike and fitted the jitsie screw and it is fine, the only thing I did was put a mark on the float body and one on the screw in the closed position to allow me to see how many turns nice and easy. The big problem I find is the tick over adjuster is a pain in the a*** to use if anyone has fitted a remote one I'd like to know what bike it came of. Quote Link to comment Share on other sites More sharing options...
moleman Posted April 13, 2013 Share Posted April 13, 2013 Jitsie ones are hard to find but these fit and work well: Kientech Fuel Screw for Suzuki DRZ400S/SM I made the adjustment end a little wider and removed the hot start button ( I have never needed it) which gives good access. got it hot, adjusted it , never touched it since. if you have a flexible screwdriver you can replace it without taking the carb off be careful not to lose the small O ring ! Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted April 13, 2013 Author Share Posted April 13, 2013 i found after running the bike upside down...the hot start is needed... Quote Link to comment Share on other sites More sharing options...
neil king Posted April 14, 2013 Share Posted April 14, 2013 The R& D remote screw works great on the 4T Quote Link to comment Share on other sites More sharing options...
moleman Posted April 14, 2013 Share Posted April 14, 2013 The R& D remote screw works great on the 4T Is this available for the Mikuni carb fitted to the Beta 4T? I can only find ones for the DRZ fitted with Keihin`s, not the DRZ`s with Mikuni`s can you post a link to the part required? Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted April 15, 2013 Author Share Posted April 15, 2013 i found the same issue./ the 2010 and up evo 4T has a Mikuni CV carb Quote Link to comment Share on other sites More sharing options...
neil king Posted April 18, 2013 Share Posted April 18, 2013 Part # AB-21081 on the American Beta web site. Yes it says it's for an FCR Kehien but it works fine on the Mikuni BSR. Quote Link to comment Share on other sites More sharing options...
