June 25, 201313 yr Author Hi Nigel, The bike is new to me 2002 txt pro. Cured the air leak by seating airbox properly on the carb. What is a banjo filter as i dont recall seeing anything when i had the carb apart ?. Been out to bike today and was wondering if my fuel tank overflow pipe was blocked ?. When checking this i found it had a one way valve fitted to the pipe and am not sure if it was on the right way round. Are these standard ? (small plastic valve which when you blow down it air will only go in one way). Not part of the cap but connected to overflow pipe. Dropped the oil and it looked like choclate milk shake. On my first ride out on the bike a couple weeks ago it overheated and was steaming like mad. I took the tank off and found the fan wire disconnected and reconected it. Has caused a further problem, Head gasket or something. Cheers Paynts
June 26, 201313 yr MIlkshake oil means you have coolant in the gearbox. The oil seal on the water pump is a common problem on Gassers. Coolant in the gearbox will make the clutch drag very badly. That is a different problem from the stalling. The symptoms you describe sound like a plugged idle circuit. Make sure it is clean, clean, clean. The tiny holes can plug very easily. I use a tip cleaner for an acetylene torch and good solvent to clean them, then blow out with compressed air. Let us know what you find.
June 26, 201313 yr Author Would it be possible for water to get in from a missing kickstart shaft support bearing ? (ie) the one behind the carb. I noticed this bearing was missing after my first ride whilst cleaning the bike, i have now replaced it with a new one.
June 26, 201313 yr Would it be possible for water to get in from a missing kickstart shaft support bearing ? (ie) the one behind the carb. I noticed this bearing was missing after my first ride whilst cleaning the bike, i have now replaced it with a new one. Are you loosing coolant, water pump seal. If not, do you use a high pressure washer ?
June 26, 201313 yr Author Have not had the tank of yet to check coolant. Yes i use a pressure washer and gave the carb a good blasting last time as i was going to take it off to strip and clean.
June 27, 201313 yr Yes it is possible that the water got in when you pressure washed it. When it overheated, the pressure in the cooling system may have pushed water into the gearbox. Either way, get the milkshake out and refill with lubricant.
June 27, 201313 yr Just checked and it says 375 ml of oil ??? doesnt seem much. Actually the first PRO (2002) had smaller engine casings. I think the amount of gear oil was 330 ml that year. -Jan
June 28, 201313 yr If the airbox is leaking dirt can get in. My guess is engine is worn and it needs a refresh. Carb has 10mm bolt on side this is banjo filter.
