Can Anyone Advise What Work Needs To Be Carried Out To The 4Rt Fuel Pump In Order For It To Fit Into A Mitani Flat Fuel Tank.
Can anyone advise what work needs to be carried out to the 4RT fuel pump in order for it to fit into a Mitani flat fuel tank.
Cheers
In simple terms and from memory, remove the pump from the bracket cut a "V" in the bracket to allow the bracket to bend over and weld back up. I have pictures of this done somewhere, if I can find them I'll send or post on here.
Hi,
Just get a future alloy pump mounting plate. It weighs loads less than the steel original .i just use a huge cable tie to clamp the pump to the mounting, others use a stainless jubilee clip.
Cheers Trev.
Is the modified way ok, as prefer not to spend £130.........
I read somewhere that the original mounting plate/bracket could rust over time (due to condens water and the crap thats in modern fuel).
So cutting a V out of it and welding it back makes the mounting plate even more vulnerable to corrosion.
And while your at it, clean the tea-bag filter that's fitted under the fuel pump. I used carburettor cleaner for it.
Edited by guys
