Power
Can an old engine develop more power ?
I put a new to me Rotax 240 engine into a SWM several months ago, it ran OK. I haven't changed the timing or carb, but have repacked the middle box and changed the back box. The increase in power wasn't instant, just a gradual improvement. The previous exhaust wasn't full of oil etc. One suggestion is the disc valve is sealing better ?
Any thoughts or am I just imagining it ?
stuck rings can free up with use
I wondered about that, but would it be gradual ?
Have you lost some weight recently......... :guinness:
Hair doesn't weigh that much !!
I'm just theorising here but if they had been stuck for a while, maybe they didn't seal too well to start with then improved as they bedded in
When I have had them unstick, it has been the result of getting the motor much hotter than normal for a brief period, and I noticed the improvement in performance pretty much as soon as the motor was back to normal temperature, and so was able to identify the cause of the performance improvement
A fresh repacked exhaust will improve the flush of a two stroke engine. The SWM doesn't have a diffusor like. My 2-stroke KTM from 1989 run much better which a repacked mid and end section. The effect might not be very much but its quite remarkable. A sticky piston ring that have come loose might also have been the case, I have heard about but never heard from anybody that have found them beside in old barn finds, but why not, sounds like a good exploration.
It could as a guess also have been a tiny piece or fibers of a cleaning rag which stuck somewhere in the carburetor and is now flushed away. when something suddenly runs better then before there was mostly a fail that got fixed by itself ...
Edited by pschrauber
do you think you may be running too much oil in the fuel you get it hot it clears and runs better just a thought
If you ditch the original tailpipe & fit a WES or similar style alloy one, you will see even more performance gain.
Always run it at 50:1 fully synthetic, the performance seems to have gradually improved.
Any particular model you can recommend ?
May be a bit stretchy what about timing. The timing of the ignition could have been changed and was not perfect adjusted when you got the engine?
With a bigger gap between the points due to wear you might now have the right timing?
This would be an explanation for the better power delivery.
BTW.:
I have ridden once the 240cc bike and in this short experience with the ride I recognized that the 240cc engine is a little bit more lively then the 280 in low to mid revs, (it was a short ride).
Hi Patrik, I like the 240 alot, nice and lively as you say, but this one has alot less flywheel weight than your 280.
The lighter flywheel sounds too, truly will eliminate the little break you have when picking up rev. but too will reduce the "rubber band" effect the engine have which I now after 1'5 years of riding with the bike like more and more.
My be I'am getting old style ???
