October 16, 201511 yr I am not shure a 4 stroke would produce more heat than a two stroke. Compression is higher and efficiency is better so for a given power output it ought produce less heat. There might be dust or dirt or something that block the airstream through the radiator. A visual check would tell. There are some strange cooling fluids around. I use battery water and 40% of anti freeze. No problem at all. But, if the bike runs well I guess the most likely fault is the thermal switch. And yes, the fan is quite noicy. Sometimes annoying. Carl Edited October 16, 201511 yr by carl ekblom
November 9, 201510 yr Author Carl, I wonder if you put some videos on the net where we could here your engine with your factory titanium silencer? Edited November 9, 201510 yr by levis
November 11, 201510 yr Well, I have to look into that. Meanwhile you can have a look at very good rider Martin Kroustek using the factory silencer. https://www.youtube.com/watch?v=VZEF_fHC8ho Carl
December 9, 201510 yr Glad to find this thread! I have a 2015 300 4t with supposedly 100 hours on it. I just got it, used. I live in San Diego, weather today is 79 F, 26 C. Idle is inconsistent. Helps when I turn it up, but then it can get too high. Fan never comes off after the bike is warm, even when I coast downhill for 30 secs at 20 MPH with the clutch in. Radator is clean. Not happy with how it idles, and with the fan always being on. It's pulling a lot of juice, which is think is exacerbating the problem - idle drops even more when i switch the lights on. Based on my weather and riding 0-4000 ft above sea level, do you guys recommend raising the needle and tweaking the fuel screw? The guy I bought this from is a dealer, he rode the bike for a year and said it should be perfectly set up...
December 10, 201510 yr So here's a quick update - I backed out the mixture screw - no mean feat as it's under the front of the carb and almost impossible to reach - and the bike runs much better. Doesn't die when you snap the throttle open, and the fan actually did shut off at one point. As far as the erratic idle - I took too much slack out of the throttle cable. When I turned the bars to the right, the cable moved and dialed in some throttle. Loosened it and she is better now.
November 19, 20196 yr I have a 2017 300 4t and the fan seems to want to stay on all the time once the engine is warmed up even when the outside temps are cool. I just checked the water pump impeller and it was good. The fan pulls a good amount of air through and back towards the engine. Is there any new news since the last post in 2015 on what could be wrong or what I could try to do to get the fan to cycle on and off? Or is this just been found to be normal?
December 2, 20196 yr I ran our 2013 & 2014 4t’s After washing down... after 10 mins sat at idle the fan would run for around 50-55secs then shut off for around 35-40 secs before switching on again... both bikes are similar on fan cycle times.
